| Introductions This is the place that you introduce yourself |
new to the 7.3
Hi everybody. For the last two years I have been scouting for a nice used PSTD 7.3and I found one ... exactly what I wanted, a 2000 SD XLT with a 7.3 and only 110,000 miles. The truck is bone stock, no mods of any kind. I got it form the original owner and it appears to have been very well maintained.
I simply do not know where to start. I guess I will head to the local ford dealer to see if the CPS is the one that is correct (the grey one I think?) and the recall done. Then I plan on ordering a spare and another o ring for it. They will ride in the glove box. Consider me a sponge ... I am interested in learning all I can from you folks and in doing a few improvement mods. I do not plan to chip this truck (auto trans) but just want good mileage. I plan to run biodiesel and perhaps some WVO. I run WVO in the benz and it runs better on that than it does pump diesel. Lots of folks have spoken highly of the PSTD 7.3 as far as using WVO goes. I hope that is the case. Looking forward to learning from all of you. Kind Regards, tretpflyer |
A chip and guages will help you both monitor potential problems and give you mileage with the correct tuning. So, chipping it is something I would look to do.
Killing time on here with my smart phone....
Glad to have you -
to the ORG!!If you haven't already, check out these forums: Ford Powerstroke 99-03 7.3L Forums - Ford Powerstroke Diesel Forum Also, check out the Carolina's Chapter: Carolina Powerstroke Association - Ford Powerstroke Diesel Forum - Might be able to tap into some info from folks local to you also. |
WOW ... that is a wild beast you have there.
I don't know if it is true or not but I have been told that upping the numbers via chipping just cuts into the gas mileage and that the auto trans can't handle the added HP. I think that these trucks are a bit "overbuilt" though and probably more stout than I think. What suggestions would you have? What chip? What gauges? What vendors? Thanks |
THANKS ... going there now. Looking forward to learning from all of you and perhaps meeting some local folks.
I have always been "gonzo" over Ford trucks and that is all I have ever owned since 1982. I have never owned an auto trans though because in college I blew out the trans on my Uncle's F150 while hauling my stuff home. It cost more to repair it than the truck was worth and he just got a new one. Ever since that, every truck for me has been a manual. This is the first ATrans. I hope it holds up well. |
Welcome to the ORG!
I wouldnt get too concerned with the trans if the truck is seeing light duty. The only issue with the auto (4r100) in our truck is overheating and this is caused by an insufficient trans cooler. Start skimming through those links provided and there will be a lot of info there that will likely cause you to have other questions. Pics are a great way to introduce yourself!! :
thanks. I like your sigpic.
I have done several mods on my bike over the years and in the early years all everybody raved about was putting in these high compression pistons and new ignition module. Turns out that $1000 and a lot of wrenching only yielded a measly 5hp. I "fell for it though and spent the dough". I DO NOT want to make that mistake with this truck. |
I just might consider doing the upgraded torque converter and a larger trans cooler.
I got 20mpg running 65-70 on the trip back home and I was babying it. Not much acceleration, but you can tell the power is there. Last edited by tretpflyr; 09-26-2012 at 06:18 PM. |
Yeah there is a lot of expensive "ideas" for our trucks and a little bit research on here will help guide you. Most on here dont buy into the "buy the most expensive parts offered because it HAS to make more power" idea.
Now, how bout some pics!! Lol |
