Hello From Albany, NY! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-09-2012, 09:15 AM Thread Starter
Shoulda done this awhile ago! Just saying hi from Albany, NY. Picked up a 2005 F250 4x4 6.0 just under a year ago. Finally started modding it. Blue Spring, Zoodad, Banjo Bolts, 4" Turbo back with Cat and Muff Delete, Harley Lights, High Idle mod, and Gauges! Any local powerstroke guys near me? This site is great btw!
DirtyDiesel05 is offline
post #2 of 6 Old 08-09-2012, 05:07 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
belated...
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 6 Old 08-09-2012, 07:50 PM
Red02F250's Avatar
Welcome! I just joined up here myself, but have had my truck for 7 years. I should have signed up years ago, there's a lot of good info and experience here.
'02 F-250 7.3 SC XLT
Mods- DP Tuner, Edge Insight digital gauge, 4" Turbo-back MBRP, 6637 Filter, AIH Delete, CCV, Donahoe Leveling Kit, X-Code Front Springs, 2" Blocks on rear and 315/75 R16 BFG A/Ts on 16x8s, OBA with viar and 5 gal tank with Grover firetruck air horns, Meyer 7.5' plow w/extensions and short v-box spreader, Atomic LED clearance lights and Whelen Vertex LEDs, Warn manual hubs, Hutch/Harpoon and Pre-Pump Filter, Coolant Bypass Filter
Red02F250 is offline
post #4 of 6 Old 08-10-2012, 04:52 PM
Other vehicle is an F250
Hank's Avatar
Welcome to the org.!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #5 of 6 Old 08-11-2012, 06:37 AM
Fifth Wheeler w/ Diesel
can05f250's Avatar
Welcome to Powerstroke Org, I just joined too and found out how to monitor the engine properly. A little late but I knew what to say when I went in for service. The info here is great.
2005 Ford F250 6.0L Lariat Ext Cab SB 4x4 'Ulysses'
July 12, 2012 with 166,892 kms - 103,019 miles
Dieselsite Coolant Filter Sys, Trail-FX LP Toolbox, Duraliner, Insight CS,
Blue Spring Upgrade, Turbo Return Pipe Upgrade, Michelin LTX M/S2 Tires
Next; SCT SF3 3015 Tuner, EGR Delete, ARP Studs, Edge EGT Sensor & Turbo Timer
can05f250 is offline
post #6 of 6 Old 08-13-2012, 08:32 AM
Tj Krawler's Avatar
There are a few others near Albany. We even have a NY chapter. Empire State Strokers - Ford Powerstroke Diesel Forum
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
