New PSD owner from PA - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-02-2012, 04:21 AM Thread Starter
Hi! I just picked up a 1996 F250 PSD 4x4 stick with 78k on the clock. Needs front fenders, front bumper, and rear wheel lips fixed but otherwise its in great shape. Aside from the rust the body is dead straight and the paint needs to be brought back to life. I have been lurking on here now for a while haha Seems to be some really great info on here! First things to do are to fix the body, undercoat, and then fix an oil leak (looks like a rear main but have been told and researched that its either the EBPV, turbo pedestal o-rings, or HPOP o-rings). Link to the beast I just bought: 1996 FORD F250 4X4 DIESEL
wishIhada5.0 is offline
post #2 of 7 Old 08-02-2012, 04:30 AM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
to the ORG!!
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #3 of 7 Old 08-02-2012, 05:20 AM
docweld's Avatar
2000 F-350 7.3 Dually
6 speed manual
4:10 rear
DIY intake
DIY 4" exhaust
Hypertech power programmer 3
docweld is offline
post #4 of 7 Old 08-02-2012, 02:29 PM
Other vehicle is an F250
Hank's Avatar
Welcome to the org.!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #5 of 7 Old 08-03-2012, 03:54 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Congrats on your truck!
Welcome Aboard, lots of useful info here you will enjoy.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 7 Old 08-03-2012, 07:12 AM
The Silent Service
colo_dually's Avatar
Quoted: 30 Post(s)
Howdy, and welcome to the ORG.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #7 of 7 Old 08-03-2012, 09:58 AM
Fifth Wheeler w/ Diesel
can05f250's Avatar
Hi and , enjoy your turck...
2005 Ford F250 6.0L Lariat Ext Cab SB 4x4 'Ulysses'
July 12, 2012 with 166,892 kms - 103,019 miles
Dieselsite Coolant Filter Sys, Trail-FX LP Toolbox, Duraliner, Insight CS,
Blue Spring Upgrade, Turbo Return Pipe Upgrade, Michelin LTX M/S2 Tires
Next; SCT SF3 3015 Tuner, EGR Delete, ARP Studs, Edge EGT Sensor & Turbo Timer
can05f250 is offline
