New to the diesel world, from Oregon - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-21-2012, 10:03 PM Thread Starter
This is my 1st diesel I've ever owned. Always wanted one and decided to get one. I have an '08 F350 CC Lariat with automatic transmission with 119,000 miles on it. I have a lot to learn on the maintenance, service and the do's and don'ts. Would like to learn and have a better understanding on how a diesel engine works. You guys know your stuff and it's an awesome forum. Going to be asking a lot of questions, I'll use the search feature before I post. Thank you!
brkncly is offline
post #2 of 6 Old 07-22-2012, 04:01 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Welcome Aboard, you will learn a ton of valueable info here. Enjoy your new ride!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 6 Old 07-22-2012, 08:42 PM
Fifth Wheeler w/ Diesel
can05f250's Avatar
Wecome to the Org. I'm learning lots here Enjoy your truck
2005 Ford F250 6.0L Lariat Ext Cab SB 4x4 'Ulysses'
July 12, 2012 with 166,892 kms - 103,019 miles
Dieselsite Coolant Filter Sys, Trail-FX LP Toolbox, Duraliner, Insight CS,
Blue Spring Upgrade, Turbo Return Pipe Upgrade, Michelin LTX M/S2 Tires
Next; SCT SF3 3015 Tuner, EGR Delete, ARP Studs, Edge EGT Sensor & Turbo Timer
can05f250 is offline
post #4 of 6 Old 07-23-2012, 07:05 AM
SuperCrutyPS's Avatar
Quoted: 298 Post(s)
Garage
Glad to have you - to the ORG!!!
Check out the OR/WA Chapter:
The Cascade Coal Rollers - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #5 of 6 Old 07-23-2012, 12:55 PM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
Howdy, and welcome to the ORG.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #6 of 6 Old 08-01-2012, 03:11 AM
Other vehicle is an F250
Hank's Avatar
Welcome to the org.!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
