New Powerstroke owner - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-01-2012, 11:34 AM Thread Starter
Hi Folks;
stumbled onto your forum, hope you don't mind that I've jumped in.
Just bought my first Diesel this last week in Longmont, CO. It's a 2007 F250 XLT Crewcab with 6.5Ft Bed;
took it on a 1000mi road trip over the holiday weekend out to the flaming gorge towing 3 rafts and frames, dryboxes and coolers. Can't say enough about the truck. hauled 13.1-13.5mpg going out and then 15.5 coming home.
Look forward to gaining insight on my truck and diesels in general from this site.
thanks.
-Scott
scottcsu is offline
post #2 of 9 Old 06-01-2012, 11:41 AM
Quoted: 6 Post(s)
Glad to have another 6.0L owner on board!! The only initial recommendation I would make would be to get a data monitor like the Scangauge2 so you can keep an eye on things.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #3 of 9 Old 06-01-2012, 11:50 AM Thread Starter
elvis, thanks for the info.
I really hesitated to buy the 6.0L truck for awhile since there seems to be a fair ammount of bad press on the injectors or the SPC connector deal.
What does the scangauge do specifically that's special to a diesel engine? I've wandered around their website and walked through the quick start manual, but didn't see anything special that my iphone and my OBD2 code reader can't do - MPG and error codes?
... I've also been looking at the Garmin EcoBoost gizmo for real-time gauging updates. Curious to know if anyone has had experience with that device too?
-scott
scottcsu is offline
post #4 of 9 Old 06-01-2012, 11:50 AM
SuperCrutyPS's Avatar
Quoted: 334 Post(s)
Garage
Glad to have you Scott - to the ORG!!
Check out the ORG's Colorado Chapter - Local guys all around you:
Centennial State Powerstrokes - Ford Powerstroke Diesel Forum
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #5 of 9 Old 06-01-2012, 12:01 PM
Quoted: 6 Post(s)
The Scangauge will monitor most of the necessary data points for the 6.0L diesel. For example engine coolant temp, engine oil temp, trans temp, ICP pressure, FICM voltage, etc.
Need to keep an eye on the difference between coolant temp and oil temp.
05 Extended Cab FX4
Ble-Blah mod...
a2elvis is offline
post #6 of 9 Old 06-02-2012, 02:48 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #7 of 9 Old 06-02-2012, 08:33 AM
The Silent Service
colo_dually's Avatar
Quoted: 31 Post(s)
Howdy, and welcome to the ORG.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #8 of 9 Old 06-03-2012, 03:53 AM
Other vehicle is an F250
Hank's Avatar
Welcome to the org.!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #9 of 9 Old 06-09-2012, 03:55 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Welcome to the ORG!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
