Need opinions on purchase - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-28-2012, 08:01 PM Thread Starter
Hi all,
I'm obviously new to the thread but I'm also new to diesels in general. I know the 7.3 has some legendary staying power with proper maintinance and this is exatly what I'm looking for.
I stumbled apon someone that found a great deal on an F550 for his new buisness and is wanting to trade my gasser for his F250 and some cash to avoid having to drive the 550 everywhere. The F250 is a 2000 7.3 6sp quad cab 4x4. It was 275000 Miles and he says it has had injectors, tranny, glow plugs, and several other things replaced recently. He got the truck approximately a year ago to use to pull a hay trailer so this is what was done to it before he got it and he does not have proof of said replacements. He has replaced the water pump in the past year and looking at it it is obviously new.
I drover the truck and it is very strong! It seemed to run very good and i couldn't find any oil from the top side of the motor. The oil cap doesn't get blown off when unscrewed either.(stuff I've seen to check from various forums) The tranny seems to be solid and the truck has a couple of after market mods. Ts 6 pos chip, k&N and a 4" exhaust. The only bad I can find is that oil appears to bee seaping from the oil plug on the oil pan. Doesnt look damaged just looks like the rubber seal/o-ring may be leaking. Oil is only on the bottom of the pan not the sides at all and doesnt seam to be dripping just seaping a little. Also ont of the blue couplers for the turbo intake has a small hole in it and would need to be replaced. Other than that it seams to be in really good shape.
I say all of that to say this. I have talked to him and lowest i can get him is 6k$ plus my 1999 Ram 1500 4x4 that books out at around $6500+/- depending on which site you use, realistically I think I could get $4900-$5200 for it. So basically I figure if I would be paying him $11000 for his truck.
Do you guys think that this would be a deal worth making? I have seen trucks similar to his in price ranges from $9000 to $14500 and various milage in my area. So I'm just looking for some thoughts.
Thanks Guys and sorry to be so long winded.
Matt
Cygan is offline
post #2 of 6 Old 05-30-2012, 07:46 AM Thread Starter
Well I guess it was a bad enough deal that no one felt they should even comment. Any way my truck sold so I will be searching for other trucks. This postcan be deleted as it is now just a waste of space.
Cygan is offline
post #3 of 6 Old 05-30-2012, 11:29 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 6 Old 06-03-2012, 03:59 AM
Other vehicle is an F250
Hank's Avatar
Welcome to the org.!
Just saw the post. Happy shopping!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #5 of 6 Old 06-04-2012, 09:56 AM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #6 of 6 Old 06-04-2012, 03:41 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Welcome to the ORG!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
