Go Back   Ford Powerstroke Diesel Forum > General Topics > Introductions
Old 09-30-2007, 09:39 AM
Woodknot Woodknot is offline
Ford 6.0 ERG Problems?
On normal acceration, engine will hestitate and make a "popping" sound - almost sounds like a gas engine backfiring thru carb - any ideas what is causing.....EGR Valve? Appreciate replys
Old 09-30-2007, 09:58 AM
ShawnCT450R ShawnCT450R is offline
Hey Woody
I'm not sure if those symptoms denote a problem with the EGR valve, however it's rather easy to rule it out. Take the EGR valve out and clean it (there is a post with the procedure for this in here somewhere) and then when you put it back in, leave it unplugged. Drive it and see if it does the same thing. It won't hurt the truck as many of us in here leave ours unplugged all the time with no problems. I hope you get it figured out bro.
Old 09-30-2007, 11:00 AM
Thanks for that information - will give it a try.
Old 09-30-2007, 11:08 AM
ABOBB ABOBB is offline
Is it even worth it???
Welcome to Powerstroke.org
Old 09-30-2007, 11:55 AM
Granny Granny is offline
The Corner Mod
Send a message via Yahoo to Granny
Welcome to the site. I hope that helps with your problem.
Old 09-30-2007, 12:08 PM
Unplugged the EGR and ran down the road without any of the prior problems - heck, that was easy!!! Not sure if I want to replace the EGR or just leave unplugged? Any thoughts? I know several have stated that they leave their EGR unplugged without any issues. Thanks
Old 09-30-2007, 12:15 PM
Southpaw Southpaw is offline
Faith, Family, Country
Not sure about the EGR, but here's a bump and a
Old 09-30-2007, 12:28 PM
Big Tone Big Tone is offline
Moderator
Only prob is the turbo doesnt put out as much boost with it unplugged.
Mine will only boost 20psi with egr unplugged, which isnt a big deal untill a cummins or dmax wants to play.
Also there are other ways to delete egr such as an SCT programmer.
Old 09-30-2007, 12:52 PM
Thanks for the reply Big Tone.... where, and how can I find someone with a SCT Programmer?
Old 09-30-2007, 12:55 PM
Rwalker Rwalker is online now
auf Bruch
Send a message via AIM to Rwalker Send a message via MSN to Rwalker Send a message via Yahoo to Rwalker Send a message via Skype™ to Rwalker
some of the vendors here can hook you up. i got mine from DJ, at DJ's diesel performance. give them a call and they can help you out!
::: DJ's Perfromance :: Home :::
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
