new at this - Ford Powerstroke Diesel Forum
Old 06-13-2007, 05:56 PM
new at this
I was told the this site could answer me some questions. I have a 1997 PSD with an edge programer my problem is when you first step into the throtle there seems to be a surge in power momentarily then it seems to fall off and excelerate like a slugish diesel does. Could this be a fuel supply problem due to the lift pump? It seems to be worse on the higher settings of the programer. Can someone help
Old 06-13-2007, 05:58 PM
Thats Mr. Oil Leak.....
1st off howdy and to the org.
I'm not sure about your problem but I would think you have low injector pressure which could be a weak high pressure oil pump.
Hopefully a tech will be along and give you a better answer.
Old 06-13-2007, 05:59 PM
to the site, I can not help you with your problem but I am sure that someone will be along soon to help.
Old 06-13-2007, 06:03 PM
Is this a hand shaker or an auto?
What gauges do you have?
Old 06-13-2007, 06:05 PM
Welcome to the .ORG!! Glad to have you and you will find plenty of info here!
Old 06-13-2007, 06:09 PM
Is it even worth it???
Welcome to Powerstroke.org
I'm not sure what to tell you about your problem.. but I'm sure one of our techs can help... there should be one along shortly.
Old 06-13-2007, 06:12 PM
pretty basic
no gauges, atomatic with tri lock converter
Old 06-13-2007, 07:18 PM
to the ORG!!
Old 06-13-2007, 10:31 PM
The Fat Mod
To POWERSTROKE.ORG
Old 06-13-2007, 10:41 PM
sounds like a week pump to me
