O.o mmmm mods. - Ford Powerstroke Diesel Forum
Old 06-05-2007, 09:31 PM
Exclamation O.o mmmm mods.
Hey guys first off id like to say that I just found this site, and so far it is amazing! A lot of props to everyone that contributes to it and I hope to become a great contributor too. Okay down to the fun stuff =) Well I just got my next vehicle and it is a 1999 F250 7.3L, its white and already has a front end and back end replacement, also a 3” add a leaf and 35” BFG All-Terrains. So to me it already looks beast. The truck was purchased brand new in 1998 so it was one of the first models of 1999, and it was owned by the previous owner until recently when I just purchased it, the truck has 134k miles but since the speedometer is off by around 6-7mph I am sure the mileage is not perfectly accurate. Well I want to start making some modifications to it, I have a lot saved up and I know generally what I want to do to it but I am not sure of the order or the right way to go about it. Or how much I could do on my own and how much I really would want to do. Originally I wanted to get a new truck and lift it and through it on 35’s or 37’s, but to me the truck already looks great and feels that way too, so I can put that off for a while, so next I wanted to start under the hood and get this truck up to a level where I can cream that vet you always see when you pull up at the red light. So I was thinking Oh! Performance chip! A buddy of mine has done this to nearly every truck he has owned and man is that thing fun, black smoke, hauling ***, there is just too much! So I was thinking on getting a chip, and I have been looking and looking but I really cannot seem to find the one I want. I really would like a programmer in specific and I would like to be able to switch it down to stock easily without having to change the whole diagnostics or anything, my friend I believe had a superchip with 6 settings and he had a 0 setting which was stock, and whenever he wanted to haul balls, he just switched it to 6 and braaaaaaaaap, so I would really want something similar to that because I could not deal with a constant diesel hog, I mean with the tires I already shot my mpg from 16-17 to 12-13, heh. So I would extremely appreciate any input or help anyone could provide me with to steer my in the right direction or even guide me. Thanks so much in advance for reading all of this and thanks to anyone who makes an effort to help me!
Old 06-05-2007, 11:47 PM
The Fat Mod
Gauges, Intake...not K&N, Exhaust...turbo back, 6 position flip chip from TS, DP or something similar. Also, a little lower gear would be something to think about. You can also get a recalibration module for your tire size. That would bring you back so you can tell what your mileage is.
Also, I moved this to the intro section for ya so more people will see it and get ya a fast response.
Old 06-06-2007, 12:13 AM
egt gauge, boost gauge, and trans temp gauge (if automatic) are a must before you get a chip and to get the most out of it I would go with a 4 inch exhaust and a good air intake on it Afe makes a good one allot of people here say k&n Is no good because it sucks to much dust through the filter but i have found that my AFE will do the same thing if i let the filter get to dry so if you get an oiled filter of any kind make sure you keep it good and oily!
I would have a custom 6 position chip burned for it with a stock setting and all the other settings you want a few come with a 140hp setting wich is allot
and with a radicle chip you well need to get a boost fooler wich is a little deal that plugs into the boost line going to the map sensor that will trick the map into thinking the engine is getting less boost than it really is (the computer is set from the factory to defuel the engine @21+ pounds of boost)
have fun and welcome to the org.
Old 06-06-2007, 03:15 AM
Almostdunfukinwidit
Welcome to the Org with the above posts
Old 06-06-2007, 05:19 AM
Is it even worth it???
Welcome to Powerstroke.org
Old 06-06-2007, 06:46 AM
Thats Mr. Oil Leak.....
with the above posts as well. to the Org!
Old 06-06-2007, 08:17 AM
Welcome to the .Org and have fun with your truck!!!
Old 06-07-2007, 04:12 PM
to the ORG!!
Old 06-07-2007, 04:13 PM
<<---"Shadow"---
Welcome!! Congrats on the truck!
Old 06-07-2007, 11:36 PM
hello and welcome
