Hello Powerstroke Forum - Ford Powerstroke Diesel Forum
post #1 of 21 Old 05-14-2007, 08:04 PM Thread Starter
I am new to the powerstroke world. Up until this point I have always had gasoline trucks. I finally out grew them when I purchased my Fifth wheel in 2000. I have finally retired my gasoline truck to my son and just purchased a 2003 F250 Super Crew with the 7.3L powerstroke. I design software during the day and hunt and play golf the rest of the time. I like to tinker and have already added a new toolbox with power center and wired it through the factory wiring so it looks stock. I will soon have my Viper alarm on it and will probably add a shortwave radio as well. I need to start beefing it up as well. I will replace the exhaust first based on the advise I recieve here. I will then look at adding a chip and new air intake system. The truck is supper clean and I am getting 17mpg in the city which is great to me. I have a website with pictures if you want to check it out...
Your Name Here | Home
Rdebault is offline
post #2 of 21 Old 05-14-2007, 08:10 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
to the ORG!!
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #3 of 21 Old 05-14-2007, 08:11 PM
Hayman's Avatar
to the site,Congrats on the new rig
Pat
2006 F350 CC
SB Beige
4"409 SS 5"Tip
2 1/2Leveing Kit
Line X Bed
Hayman is offline
post #4 of 21 Old 05-14-2007, 08:28 PM
NoSpark's Avatar
regulator spring and banjo bolts upgrade, Sinister EGR Delete kit, SCT X3 SRL tunes, 4" MBRP exhaust, CFM+ intake kit, Isspro Gauges, By-pass filter, zoodad mod, CCV mod
NoSpark is offline
post #5 of 21 Old 05-14-2007, 08:32 PM
Is it even worth it???
ABOBB's Avatar
Welcome to Powerstroke.org
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
post #6 of 21 Old 05-14-2007, 08:37 PM
CW4 Retired, US Army
uhpilot's Avatar
Welcome Aboard!!!!!!!!!
Ricky T.
2007 F250 Crew Cab Lariat FX4
Southern Comfort Edition
Edge SCT
SCT Tuner w/a few "Looney Tunes"
6" Pro Comp suspension lift
Bilstein Shocks
Nitto Trail Grappler 35x12.50R20LT
uhpilot is offline
post #7 of 21 Old 05-14-2007, 08:43 PM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Welcome. It's interesting that diesel pickups despite weighing upwards of 1500, 2000lbs+ in most cases get much better mileage than gasoline powered trucks. It's a trend that will continue, but I think it will still be a slow one for cars.
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
post #8 of 21 Old 05-14-2007, 09:32 PM
The Fat Mod
Logan's Avatar
To POWERSTROKE.ORG
I dont think your link is bring up any pics. Maybe I didn't wait long enough. You can upload some pics in your garage. And fill in your signature and create an Avater under user CP.
Logan is offline
post #9 of 21 Old 05-14-2007, 09:50 PM
rankroddin250's Avatar
dont forget a good set of gauges B4 you get your chip especialy since it is going to be towning! you need at the verry least a Pyrometer (Exhaust gas temp) gauge and if its an automatic a tranny temp gauge is a must along with a good tranny cooler. if its a manual the rear dif temp gauge is becoming fairly comon and a boost gauge is recomended so you know when to let out of the go go pedal if boost preasure starts getting high enough to cause engine failure its also a good diagnostic tool if your having problems that could be related to the induction system... plus its fun to watch when you stand on it
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #10 of 21 Old 05-14-2007, 10:03 PM
im fat and ugly
stump0331's Avatar
welcome aboard
2004 Excursion
stump0331 is offline
