Water pump replacement 2000 7.3 Diesel - Ford Powerstroke Diesel Forum
Old 04-19-2007, 09:24 AM
Just wanted to say thanks to the site and to marc for the water pump replacement guide for the 7.3. I was surfing the net looking for help when I found the site. I was really stressed when I noticed that the pump was leaking and needed replacement. I called the local Ford store they wanted $668.00 just to replace the pump. I am just a little bit more then a begginer home wrencher, with a good set of Craftsman's. So I was not sure I could tackle it. The easy instructions Marc gave made it pretty simple. He was dead on for my truck. I actually thought there is no way that this going to smooth. I was waiting for some major hurdle but it never happened. I obtained the fan-clutch puller like it said from Autozone, loaner tool you get your deposit back when you return it. I also chose to replace the belt .($63.00 from Ford). I chose to go with the pump from Autozone it has a lifetime warranty it was $159.00 Ford wanted $300.00 I'll let you know if it lasts? Replaced the thermostat($43.00) from Ford, and the upper Rad hose $22.00 KragenAuto, and the lower Rad hose $25.00 KragenAuto. It was time consuming cause I went slow so I did it right. Cost was $328 I saved about $500.00 doing it myself. Would not have attempted it without the Help!! Thanks to the site and Thanks to Marc for his simple instructions. If you find yourself like I did, use Marc's instructions and give it a try, You will save alot of Dough!!!!! Thanks!!!!
Old 04-19-2007, 09:36 AM
duct tape & zip ties
Glad you got your truck fixed. By the way welcome to the site.
Old 04-19-2007, 02:10 PM
BIG TRUCK, SMALL DRIVER
Welcome to the Forum!
Glad you got it goin'!
Old 04-19-2007, 03:18 PM
Thats Mr. Oil Leak.....
howdy and
Old 04-19-2007, 04:42 PM
Welcome to the site man, Glad those instructions helped ya!!!
By the way, where in california are you??
Old 04-19-2007, 04:45 PM
marc is a lifesaver... that and a chick magnet lol
Old 04-19-2007, 06:54 PM
to the forum
Old 04-20-2007, 10:15 PM
The Fat Mod
To POWERSTROKE.ORG
Old 04-21-2007, 12:41 AM
to the site.
Old 04-21-2007, 06:07 PM
Welcome, and glad it all worked out for you, now it's time for the mods hahaha.
Gord
