Hello and Help - Ford Powerstroke Diesel Forum
Old 04-17-2007, 05:03 AM
Hello and Help
Hello from the Grass Valley area of Northern California
My truck is a 99.5 F250 4x4 Crew Cab that my son and I picked up in Tulsa about 2 years back(cheaper there). Its stock with about 180k mi and we used it as a main transportation vehicle and as a tug for our camping trailer that we use far too infrequent. Up to this point its been a great vehicle...we can pack and pull the farm with it. Yesterday while my wife was driving it home on the freeway it lost all power and she had it towed to a local outfit for repair. Once the tow truck put it down they tried starting it up and it started right up! She paid the obligitory $40 for opening the hood and cleaning a few things then she pointed the grill home...and made it about 2 miles down the road where it pooped out again. Its now back at the fixit shop waiting for my direction. Any one out there have a suggestion as to what's the problem? Appreciate your comments.
Thanks,
Tom
Old 04-17-2007, 05:26 AM
Is it even worth it???
Welcome to Powerstroke.org
I'm not a tech.... so take anything I tell ya with a grain of salt, but what you describe sounds like a classic CPS (Crank Position Sensor) problem to me. If that is indeed what it is, and you know one end of a wrench from another, it should be an easy self fix, if you don't want to pay the shop.
Here is a link to a really good write up on how to replace the cps: 7.3 Cam sensor replacement procedure
Many of us with 7.3 engines keep a "cps kit" in the glove box. It's just a couple of simple hand tools, and a spare sensor that will help to keep you from getting stranded.
Old 04-17-2007, 05:43 AM
Welcome to the forum. I agree with Aaron. Sounds like the cam sensor to me as well. I have replaced several of them with the same symptoms that you are describing. Good luck witht he fix and if you have any problems or questions, feel free to ask. Someone here will jump in and help.
Old 04-17-2007, 05:45 AM
duct tape & zip ties
I concur with you Aaron CPS is most likely the culprit here. When you buy one, buy two. Keep the extra in the glovebox. As you may never know when you need it. The CPS fails when it feels like it. Kinda like a computer it crashes with no warning.
The CPS is a easy repair, the link provided by ABBOb is a good writeup.
Old 04-17-2007, 07:01 AM
Conservative and Proud
by the by ..... WELCOME ABOARD!!!!
Old 04-17-2007, 09:36 AM
to the forum
Old 04-17-2007, 10:08 AM
Thats Mr. Oil Leak.....
Howdy and
Old 04-17-2007, 07:20 PM
Thank you too all for the warm welcome and helpful advice. A quick question though...The codes were read and no fault codes came up. Could the CPS still be bad and there not be any codes come up? Not surprising....a new fuel filter didn't do the trick.
Thanks
Old 04-17-2007, 07:23 PM
Thanks
yes...the CPS does not always throw a code...
Thanks
my truck was doing the same thing and it wasnt throwig any codes out.. i still had warranty so i just had it towed to my ford dealership and they fixed it....
