Go Back   Ford Powerstroke Diesel Forum > General Topics > Introductions
Old 10-31-2009, 05:55 AM
diablos30 diablos30 is offline
FNG
name is chad and im located in north carolina. first time diesel owner, just picked up a '06 250xlt with 49k on the clock.
loving it so far with only a vacuum leak to track down (defrost only).
looks like a ton of great info here and hope to stick around and contribute.
Old 10-31-2009, 09:20 AM
westcoaststrokin westcoaststrokin is offline
Go Navy! Beat Army!
to the ORG!!
Old 10-31-2009, 09:41 AM
HVAC SuperTech HVAC SuperTech is offline
Scott loves the Squirell
welcome to the org and check out the carolina powerstroke (CPA) section. we'd love to have you as a member!
Old 10-31-2009, 10:06 AM
Ozone-etr1 Ozone-etr1 is offline
jumpin jiggawatts
ok mine did this and i'll save you the trouble.
first check the assoiated fuse per the owners manual..for the vacume pump...OR,
if your 4x4 then trace the vacume hose that goes into the knuckel on the front axel.
that actuates the 4x4 when "on the fly" clamp off one side start the truck and see or feel if the air moves to the window vents, if not then do the other side and check.
NOW!, if not 4x4 thenallow the truck to sit for a min if youve driven it.Then pop the hood with your head hangin out the window turn the ignition to the "ON" position
dont start it! you should here three things the pain in the ear dinging from the dummy bell,the injectors cycling and a "HUM" like a pump thats the one your working on.Its on the passenger side wheel well behind te AUX batt if so equipt.
It will have 2 or three hoses and a couple of branch lines thoes go to diffrent aireas of the truck.now clamp off one of the 3 that come DIRECTLY off the pump.then start the truck and feel if the defrost is working if it does then its on that leg of vacume,if not go to the next.
Once found on what mauin leg the leak might be then see if it branches off or "T's"
any where on that main vacume line.if so then clamp off one side of that line try to start it and feel for the defrost to work. if not then try the other side of the "T'" and wala you have it replace that side as best you can.
saving the best for last...
if all this doesnt work then you its behind the dash and yo need to start traring parts off till you can see all the actuators and conectors. tht should help
Old 10-31-2009, 12:30 PM
ABOBB ABOBB is offline
Is it even worth it???
Welcome to Powerstroke.org
Old 10-31-2009, 02:25 PM
thanks for the welcome and i found the leak. was one of the connectors that looked like it was connected but wasnt. popped it back on and good to go.
will check out the carolina section.
Old 10-31-2009, 02:34 PM
Hank Hank is offline
C.P.A. Officer
Welcome to the org.!
We have a CPA get together next Saturday in Georgetown, SC at Shanes's (Sea71).
Old 10-31-2009, 02:35 PM
RRonning1984 RRonning1984 is online now
Heavy Equipment 911
Welcome to the ORG!
Old 10-31-2009, 04:35 PM
95dieselsmoke 95dieselsmoke is offline
keep yer eye on the prize
Old 10-31-2009, 05:07 PM
jumpin jiggawatts
hmm
or cold be that
