need help on power loss - Ford Powerstroke Diesel Forum
Old 02-18-2007, 05:30 PM
Unhappy need help on power loss
Any ideas, 01 dually running edge attitude 4 dp 5 exhaust k&n intake. Had
number 8 injector go out two weeks ago. I've recently had both valve cover
harness changed out. Changed out fuel filter about a month ago. Ran great
after injector then it seemed to loose power again. It did gel up on me last
tues. put additive in drained fuel filter and still had the power problem. I took
it to the dealer being I have no access to a scan tool, they can't find anything wrong. Did cylinder test and injector test check turbo no sure what else they kept the paper work and left the work order open. I did disconnect
the ebp sensor but no change. I'm not seeing any smoke but do have more
than usual soot on the truck itself but I was kind of contributing that to the new exhaust being a little shorter than stock. No tip yet..The power loss seems like a miss and does it more under load than at idle. Not as bad on straight aways but hills it sucks. You can deffinitly here it in the motor that
its not running right.Please help...Sorry so long...
Old 02-18-2007, 05:36 PM
The Fat Mod
First off...
To POWERSTROKE.ORG
Did you change the fuel filter after the gel incident? That maybe it, got cloged and is starving the motor for fuel?
Old 02-18-2007, 05:45 PM
hey i had the same problem on my 95 f250. come to find out the catyletic converter was bad clogged up and not releasing exhaust.
fixed it and know it runs like it was new.
Old 02-18-2007, 05:48 PM
No cat on exhaust change, I didn't change out the filter I thought about it
but it was going down hill before that. I guess it wouldn't hurt..
Old 02-18-2007, 05:51 PM
im fat and ugly
hope we get ya fixed up
Old 02-18-2007, 05:54 PM
The Fat Mod
Yeah, anytime you gel, you need to change the fuel filter. It maybe something else, but that def wont hurt.
Old 02-18-2007, 05:59 PM
I'll do that..thanks for the help and welcome. Could there still be a injector
on the way out thats not showing up on scan?
Old 02-18-2007, 06:01 PM
The Fat Mod
Did they do a buzz test or anything like that? Or did they just scan it with a scan tool?
Old 02-18-2007, 06:02 PM
to the site
Old 02-18-2007, 06:13 PM
They said they did comp. checks on cylinders and injectors not sure since I don't have paper work. Told they couldn't find anything wrong. The guys suppost to be a master mech. on diesels. LOL If it dosen't show up on scan
they don't know??What gives there..
