Go Back   Ford Powerstroke Diesel Forum > General Topics > Website Comments, Suggestions and Announcements > Ideas and Suggestions
Ideas and Suggestions If ideas are never brought up, they never have a chance of happening!!!
Old 01-04-2009, 02:11 PM
workin4my350 workin4my350 is offline
How about a little terms definitions? (newbie Q?)
Hey all,
I know this is a stupid suggestion, but what about a thread titled TERMS? I have a hard time following sometimes. I have been a lurker for a bit,and just joined up. I want to do all the standard maint. and want to do a few things to the rig.
It would be nice for a mod, or member to add a terms log for different terms, it would be super nice to be able to have tech links for tips too?
Just throwing this out there. We are not all techs, or full time pullers whom know it all.
New guy,so please dont shoot me dead too soon.
Bill
Old 01-04-2009, 02:14 PM
HunterJ HunterJ is offline
So you mean acronyms like HPOP and VGT?
Old 01-04-2009, 02:17 PM
exactly I have a hard time following,and spend too much wasted time looking up these terms and then trying to follow along.
I hate showing my ignorance, but a little pic, and answers to what these acronyms are would be great for the new guys how only know little.
Bill
Old 01-04-2009, 02:19 PM
Big Tone Big Tone is offline
There is a list around here somewhere?
Looking for it.
Old 01-04-2009, 02:21 PM
the2ndtinman the2ndtinman is offline
Send a message via ICQ to the2ndtinman
i think is is a great idea and have thought of it myself. I pretty new to diesels and get confused as well.
HPOP is High Pressure Oil Pump
ICP is the Injector Controll Pressure Sensor
IPR is the Injector Pressure Regulator (high pressure oil regulator)
FICM is Fuel injector controll module (6.0)
IDM is Injector driver module (7.3)
PCM is Powertrain controll module
LOF is Lube, Oil, Filter
CMP or CPS (cmp is the dealer term, cps is the forum term for some reason) is Camshaft position sensor
UVCH is under valve cover harness (7.3)
Y pipe is the pipe at the back of the motor, that comes off the exhaust manifolds to feed the turbo
MAP sensor is manifold absolute pressure sensor, how the PCM knows boost levels. It is Boost+atmospheric pressure
MGP is manifold gauge pressure, or true boost (MAP-atmospheric pressure)
EOT sensor is Engine oil temp sensor
EGT is Exhaust gas temp (never a factory sensor)
ECT sensor is Engine coolant temp sensor
H2o pump is water pump
P/S is powersteering
IAT is Intake air temp sensor
IAH is intake air heater
CAC is Charge air cooler. A CAC tube is either tube that runs from the intercooler to the motor
Rad is Radiator
CCV is crancase ventalation
Degas bottle is the coolant bottle on a 7.3 or 6.0 where the radiator cap is on the bottle and not the radiator
APP is acelerater pedal position
ABS is antilock brake system
SRS is suplimental restraint system (air bags)
OD or O/D is overdrive
EGR is exhaust gas recirculation (6.0 and 6.4 only). It consists of a valve, and cooler(s)
WOT is Wide open throttle, or pedal to the metal
Old 01-04-2009, 02:22 PM
2x4 =Two Wheel Drive
4L100 =Automatic Transmission 4 Super Duty Trucks
4x4 =Four Wheel Drive
ABS =Anti-Lock Braking System
AC =Air Conditioning
AIC =Auxiliary Idle Control
APCM =Auxiliary Power train Control Module
ATF =Automatic Transmission Fluid
BARO =Barometric Pressure Sensor
BB =Bulletin Board
BBS =Bulletin Board System
BCA =2nd Best Bearing Company
BTW =By the way
CC =Crew Cab (4 door)
CCV =Crank Case Vent
CDR =Crankcase Depression Regulator
CPS =Cam Positioning Sensor
DORA =Dealer Order Receipt Acknowledgment
DRW =Dual Rear Wheels
DTC =Diagnostic Trouble Code
DVOM =Digital Volt-Ohm Meter
E4OD =Auto Transmission on Pre-'99 Ford Pickups
EEC =Electronic Engine Control
EGT =Exhaust Gas Temperature
EOT =Engine Oil Temperature
FAQs =Frequently Asked Questions
FPR =Fuel Pressure Regulator
FWIW =For What it`s Worth
GM =General Motors
GP =Glow Plug
GPR =Glow Plug Relay
GVWR =Gross Vehicle Weight Rating
HEUI =Hydraulic Actuated Electronic Controlled Unit Injector
HPOP = High Presure Oil Pump
IAT =Intake Air Temperature Sensor
IDM =Injector Drive Module
LMAO =Laugh My Arse Off
IMHO =In My Humble Opinion
IMO =In My Opinion
LB =Long Bed
LOL =Laugh Out Loud
MAF =Mass Air Flow Sensor
MAP =Manifold Absolute Pressure Sensor
OBS =Old Body Style
OD =Over Drive
OEM =Original Equipment Manufacturer
OTC =Owatonna Tool and Equipment Company
OMG =Oh My Gosh*
PCM =Power train Control Module
PCV =Positive Crankcase Ventilation
PDL =Power Door Locks
PM =Power Mirrors
PS =Power Stroke
PSD =Power Stroke Diesel
PTO =Power Take Off (winch)
PTTTM =Power Telescoping Trailer Tow Mirrors
PW =Power Windows
PWM =Power Window Motor
RC =Regular Cab
ROFL =Rolling On The Floor Laughing
SB =Short Bed
SC =Super Cab (extended cab)
SRW =Single Rear Wheel
TC =Torque Converter or Transfer Case
TPS =Throttle Position Sensor
TSB =Technical Service Bulletin
TTM =Turbo Temp Monitor
VAC =Volts Alternating Current
VDC =Volts Direct Current
VECI =Volts Direct Current
W/E =What Ever
WOT =Wide Open Throttle
HPOP Hpressure Poil Pump
Old 01-04-2009, 02:23 PM
cliford cliford is offline
theres a website somewhere trying to find it.
guess harohunter beat me to it!
Old 01-04-2009, 02:28 PM
I think Mark(Mschn99) Posted some of these.
