Go Back   Ford Powerstroke Diesel Forum > General Topics > Website Comments, Suggestions and Announcements > Ideas and Suggestions
Ideas and Suggestions If ideas are never brought up, they never have a chance of happening!!!
Old 09-27-2006, 08:41 AM
adam95 adam95 is offline
smokin n strokin
TS chip installation/down pipe install
i just ordered a TS six position on ebay for $265 i hope it works good, anyways how hard are they to install or where can i find directions on how to install..., bye the way thanks for all your helpful hints guys i went ahead and got a pyro/boost gauge pillar setup and its pretty sweet looking, I also got one more question, i herd i might have to bend in my firewall by the floor pan to fit in a 3" down pipe on my 95 psd is this true.and Thanks again guys
Old 09-27-2006, 08:53 AM
Glenn M Glenn M is offline
The TS should come with directions, just make sure you get all the Shellac type stuff off the contacts. On your truck, there is a body seam on the firewall, that some people say they had to beat over to fit the bigger pipe.
Old 09-27-2006, 08:58 AM
Logan Logan is offline
The Fat Mod
Hey Adam, the TS is not bad to stick in. Maybe an hour or less and you should have it done. Just make sure you clean your board REALLY REALLY REALLY god before you stick your chip in. Clean it until you see just a little shine off the contacts. Just be careful to not clean a hole through it or anything.
Putting your guages in is not bad either, just be sure to go slow and grease your bit when drilling for your pyro. Want to keep the metal shavings out. After that it is just a matter of running your stuff and hooking it up.
For the down pipe, Not sure on yours but I am sure someone will know soon and be able to give ya a hand with that part. Good Luck
Old 09-27-2006, 10:39 AM
CHenry CHenry is offline
Sooner Powerstroker
When you drill the manifold for the pyro probe, it's also recommended to start the truck and let it idle as you drill.
Old 09-27-2006, 11:34 AM
The Fat Mod
Thanks clay, forgot about that.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
