Go Back   Ford Powerstroke Diesel Forum > General Topics > Website Comments, Suggestions and Announcements > Ideas and Suggestions
Ideas and Suggestions If ideas are never brought up, they never have a chance of happening!!!
Old 09-26-2006, 09:00 AM
adam95 adam95 is offline
smokin n strokin
TS chips
what is a TS chip, are they really that good and where can i get one thanks guys. also i know its stupid but what's "ses" is that the emissions light what would cause it to come on and is it a problem.
Old 09-26-2006, 09:38 AM
gcop gcop is offline
PIPE HITTER
The TS chip is a 6-position chip stock, 60, 75, 100, and 140 HP settings, there si a spot in there for valet, and high idle also. The chip plugs into your PCM and thats about it. It's is for the 7.3. 95-02.
If you are considering doing the chip or any progrmmer/chip gauges should be your first priority as you will need at minimum to monitor EGT's to make sure nothing melts. You should do a full exhaust as well that will help reduce EGT's, and of course and intake as well.
Hit up some of our vendors here, they can get you great prices and advice on whatever you may be interested in.
And yes you are right about the SES light, "service engine soon". Your best bet when you see that, is to take the truck somewhere and have the code read, then folks here can help you better figure out whats going on. If there is an Autozone in your area they will do it for you free as will most other auto parts stores.
Old 09-26-2006, 10:29 AM
mech2161 mech2161 is offline
You can check with Patrick at Discount Power. They handle TS and just about anything else you might need.
PS
Larry is on business in TX for the next few weeks and Pat can't get to every call. Leave him a message or contact me and I'll hunt him down.
Old 09-26-2006, 10:33 AM
99Smokin73Stroker 99Smokin73Stroker is offline
Grammar Police Chief
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
If you got a TS you'll see the SES light once you go over 21lbs of boost I think it is......unless you cet the map sensor fooler.......whatever it's called, I have forgetten!
Old 09-26-2006, 10:58 AM
CHenry CHenry is online now
Sooner Powerstroker
Of course if you drive a dodge you get used to seeing the SES light.....
Old 09-26-2006, 11:04 AM
Not really.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
