Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > Get er on the Dyno
Get er on the Dyno Let's see the numbers!
  #11 (permalink)
Old 10-29-2008, 08:09 PM
Dirk Dirk is offline
Diesel Innovations
I've put down over 900lbs of torque on my stocker.
  #12 (permalink)
Diesel Innovations
I would call BTS and get a VB.
  #13 (permalink)
Old 10-29-2008, 08:10 PM
Matt P Matt P is offline
a truck
Wow thats insane, makes me feel better about dynoing then. Thanks again for the help Dirk and everyone else\
how much are BTS VBs ?
  #14 (permalink)
Old 10-29-2008, 08:12 PM
Diesel Innovations
390ish without a core. Send back your old one and get $150 back.
  #15 (permalink)
Old 10-29-2008, 08:16 PM
a truck
thats a good price I was thinking about getting a VB since I cant afford a fully built trans how will my trans hold up with just the VB and a stock TC will it be pretty helpful. Ive acutally been meaning to ask these questions so now that my dyno question was answered I hope you dont mind a couple more. lol
Also I was lookin at racerxautomotive VBs, any opinion on those. Sorry for so many questions
  #16 (permalink)
Old 10-29-2008, 08:21 PM
Diesel Innovations
With stage 1's? get a vb and a larger cooler. Keep the stock pan.
I would not install anything other than BTS. As soon as I get another stock VB, I'll test out John Woods VB. I hear they are very good also.
I gave away a FTVB. Had nothing but issues. I had the trans screaming at me at the rev limiter not wanting to shift using some seriously extreme tunes.
The man who wrote the tunes was in the truck as a witness. I'll let you guess who that is. Now the trans shifts properly under WOT or part throttle with ease.
  #17 (permalink)
Old 10-29-2008, 08:22 PM
95dieselsmoke 95dieselsmoke is offline
keep yer eye on the prize
i would like to know also matt. just subscribing here
  #18 (permalink)
Old 10-29-2008, 08:25 PM
a truck
Ok cool then I will definitely stick with a BTS VB then and 240 after sending the core back sounds good to me, only Ive never messed with transmissions so I would probably have to have it done unless its not too hard to do. I can guess who the guy that wrote the tunes was. lol. So if I get a VB and a bigger cooler with stage 1s Ill be in good shape with my trans, would you just recommend doing a 6.o cooler?
  #19 (permalink)
Old 10-29-2008, 08:30 PM
Diesel Innovations
40k gvw cooler should be good.
Installing the VB is simple. Just need a inch-pound torque wrench or very light and accurate ft pound (5-30lb) torque wrench. I think its only 9 or 13 bolts to remove the old unit and stick the new one on (once the pan is removed).
  #20 (permalink)
Old 10-29-2008, 08:32 PM
a truck
Ok so theres no special tools needed really just undo those bolts and drop the VB and put the new one in then what are those torqued to?
