Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > Get er on the Dyno
Get er on the Dyno Let's see the numbers!
Old 11-17-2006, 07:32 PM
Ronin Ronin is offline
6.0 Dyno Numbers, SCT w/ID tunes...
Finally got my ride to the local speed shop to get my Quadzilla Commander installed. They also threw in the Bilsteins that I had waiting around while they were at it. I didn't get to install the full AiRaid intake that I bought, we're saving that for next time...
Anyway, with the mods listed below, and my SCT Xcalibrator 2, we did stock (no program), Street tune and Xtreme Street tune pulls.
Since all dynos are different, and this is my first time with a one of the 4-wheel variety, I'll leave it to the experts to determine what's what as far as the one they use is concerned.
I'll try to scan and get the actual sheets posted, but here are the best numbers from the multiple runs with each configuration. After 3/4 runs heat soak definitely started to become an issue...
STOCK:
233.6 HP (3446 RPM)
356.1 Torque
20% load
ID STREET TUNE:
365.0 HP (3655 RPM)
524.4 Torque
ID XTREME STREET TUNE:
363.0 HP (3295 RPM)
578.7 Torque
I was expecting closer to 400 HP and much closer to 700 Torque based on what I've read and seen, but all dynos are different so I thinking it's all relative. No puking at all with any tune, and EGTs barely broke 1K, which I was happy about. I think the max Boost was 21 PSI, which I thought was kind of low, so I'd like to hear some feedback.
Also on that note, I didn't see much boost unless it was under load, and or going up a hill. I saw no more than 20 PSI when I was towing later that afternoon.
I don't wanna push my luck, but if the turbo is supposed to be putting out more (I thought on the Xtreme Street tune I would be up around 30 PSI) then I need to look into fixing and or replacing it. I'm definitely happy, I just want to be happier.
I was really glad to find out the shop's experienced with water/meth injection. That's next on the list when I'm sure what's going on with the turbo. We were thinking a Snow Stage II, with probably no more than a 70/30 mix, just have to get the nozzles dialed in.
Let me know what you all think. Thanks,
Matty
Old 11-17-2006, 07:41 PM
stump0331 stump0331 is offline
SNAFUSTUMP‹^›‹(•¿•)›‹^›
Tournaments Won: 1
i would expect higher numbrs with that sct as well
Old 11-17-2006, 07:58 PM
Comparatively speaking, the increase from stock of 130 HP and 220 Torque seems to be in line with ID tunes claims/experience, just the baseline numbers are low to begin with. I'd attribute it to dyno specific peculiarities, and absent a run on a different dyno it's the best I have to go on...
Matty
Old 11-18-2006, 06:16 PM
06SIXLITER 06SIXLITER is offline
50ft/lb difference between street and xtreme street???
That normal?
Old 11-18-2006, 06:32 PM
That normal?
I dunno, that's why I'm gonna follow up with Eric @ ID shortly. It might be dyno related, but I'm gonna double check to make sure...
Matty
Old 12-06-2006, 03:20 AM
Tournaments Won: 1
Matty
ever find out anything???
Old 12-06-2006, 12:03 PM
Stump,
I heard back from Eric (@ Innovative Diesel) and passed his comments and contact info along and my dyno guy's gonna get with him. Sounds like the dyno wasn't loaded properly. I'm gonna have plenty of reasons to go back so that's just fine with me, we'll get it dialed in...
Matty
Old 02-12-2007, 08:51 AM
Patrick Patrick is offline
Ronin, my truck ran a 422hp with Elite and 411hp with ID, but just as your chart shows. Yesterday the dyno tech had troubles holding the direct drive gear on the automatics. You have to be able to get into drive, let it bog down a bit, and then run it up without downshifting.
Your RPMs are way too high.
Old 02-17-2007, 02:59 PM
99gt 99gt is offline
holy...stock 6.0 only dyno's 233hp? That's like 30% drivetrain loss
Old 02-17-2007, 03:21 PM
iracemx6 iracemx6 is offline
Don't get hung up on dyno numbers.Due to different dyno's and the operators the numbers vary too much.
Most die hard guys will tell you to weigh your truck with you in it and run it at the strip in the 1/4 mile and calculate the horsepower that way.
It is easy to do and pretty accurate.
I would bet with the Xtreme Street you are closer to 400rwhp and with the Xtreme Race somewhere around 410-420.
