Fass 150 lift pump - Ford Powerstroke Diesel Forum
Georgia Members Georgia Powerstroke.org Members Forum
post #1 of 4 Old 08-10-2014, 04:24 PM Thread Starter
Huntinjake_23's Avatar
Fass 150 lift pump
Hey guys I'm looking at adding a fass 150 lift pump to my 97 f350 crew cab long bed. Has anyone done this, any input will help. Also does fass sell the set up that is compatible with having duel fuel tanks??
Thanks
Jake
Huntinjake_23 is offline
post #2 of 4 Old 08-10-2014, 06:55 PM
RaisenCain's Avatar
Honestly if you're running a completely stock truck it won't do much. Help yes but not in any way noticeable to you. Honestly if you're planning on putting some power eventually I would get yourself some gauges before anything.
02 Crew Cab. TS Chip. DIY 6637. 4" Straight pipe. Triple gauge pillar. Boost fooler. Regulated return & lift pump on the way
RaisenCain is offline
post #3 of 4 Old 08-10-2014, 07:09 PM
Macon's Avatar
What he said, plus, dual tanks is only a switch away. If you install the pump after the switch (i.e., in replacement of the oem pump), then it won't care where the fuel is coming from.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 4 Old 08-10-2014, 07:43 PM Thread Starter
Gauges are on the way, as well as an air intake and straight pipe exhaust. I will eventually put more into it as the funds come available. Thanks off the input.
