New Powerstroke owner - Ford Powerstroke Diesel Forum
Georgia Members Georgia Powerstroke.org Members Forum
post #1 of 11 Old 08-04-2014, 07:47 PM Thread Starter
Huntinjake_23's Avatar
Hey y'all just introducing myself, my names Jake and I'm 24 from Loganville, Ga just bought my first Powerstroke; it's a 1997 F-350 crew cab long bed white paint with the gray interior. It's bone stock other than some new wheels and tires and only has 96,600 miles. Let the fun begin!!!!
Huntinjake_23 is offline
post #2 of 11 Old 08-06-2014, 02:44 AM
Wed Turner's Avatar
WOW! Nice find on that truck. Looks like it's clean and straight. Welcome.
2003 Excursion Limited 6.0 2wd
Transmission built by
/ ECM tunning by
/ FICM tunning by
Coldside Intercooler Kit /
EGR Delete /
Coolant Filter / GoGo Diesel direct clutch solenoid / AFE Stage II Intake / Ford Blue Spring / 6.4 Banjo Bolts / Zoodad / 1.5" front sway bar by
/ Ford 30mm rear sway bar
Wed Turner is offline
post #3 of 11 Old 08-07-2014, 08:52 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Welcome to the addiction, glad to see more obs rigs out here, what's your plans for it?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 11 Old 08-08-2014, 10:47 AM Thread Starter
Gonna start with 4 inch turbo back exhaust w/ no muffler, then gonna get an air intake, eventually add an intercooler and bigger turbo at some point, and later down the road a tuner with bigger injectors. Any suggestions please feel free to let me know.
post #5 of 11 Old 08-08-2014, 10:56 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I'd do the injectors and turbo either the same time or injectors first, because a big turbo would be pretty laggy with stock injectors, I've actually intercooled 3 obs rigs now, I can help with install or parts required if you want to DIY, or do a kit, as far as intakes go try looking up the DIY 6637 it's cost effective and one of the best out there for our rigs,
Any idea on who's tunes you want to run? I've had great luck with tony wildman on my rigs, looking at php or dp tuner for my sd however just to try it out
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 11 Old 08-09-2014, 09:27 AM Thread Starter
Still looking around, haven't put that much thought into yet, my buddy mentioned and showed me the banks big hoss kit, the price on it scares me a bit, but I know banks has good stuff.
post #7 of 11 Old 08-09-2014, 09:52 AM
Wed Turner's Avatar
I am not super familiar with the 7.3 offerings but I bet you could find stuff out from other vendors than Banks that is cheaper and just as good or better. Banks makes decent stuff butabut a lot of the cost is just the name.
/ ECM tunning by
/ FICM tunning by
EGR Delete /
post #8 of 11 Old 08-09-2014, 11:27 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Banks is very expensive stuff, I've intercooled 2 obs trucks for under $400 combined tho, the set up on my 95 I'm into for about $215 rite now, my old 97 I had $180 in, and I did a buddies rig for about $225
Just something to keep in mind, a lot of the good mods can be had with some thrifty searching
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 11 Old 08-10-2014, 06:54 PM
RaisenCain's Avatar
Welcome to a habbit.
02 Crew Cab. TS Chip. DIY 6637. 4" Straight pipe. Triple gauge pillar. Boost fooler. Regulated return & lift pump on the way
RaisenCain is offline
post #10 of 11 Old 08-10-2014, 07:13 PM
Macon's Avatar
Banks was the best stuff I knew about before I got into it myself. I give credit to an awesome advertising department. Banks isn't the best, nor the cheapest, and not even the most friendly. Snoop around the forums, post up in the soot thread, and you'll get set in the right direction. 351fifty is good folk and will not steer you wrong on OBS stuff.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
