injector help - Ford Powerstroke Diesel Forum
Georgia Members Georgia Powerstroke.org Members Forum
post #1 of 18 Old 09-17-2013, 07:24 PM Thread Starter
injector help
any one in the henry county area willing to help pin point an injector problem
helms_justin81 is offline
post #2 of 18 Old 09-17-2013, 08:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What engine, I'm in Cherokee county tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 18 Old 09-20-2013, 04:28 AM Thread Starter
its a 7.3 and has a skip. the scan tool I have doesn't do buzz test and what not to pin point injector issues
post #4 of 18 Old 09-20-2013, 07:45 AM
jmsmith76's Avatar
Any DTC's at all? Any other symptoms besides the skip?
jmsmith76 is offline
post #5 of 18 Old 09-20-2013, 09:09 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
How far are you from Cherokee county, if your close enough I can just brig my scan tool and help ya, pm me
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 18 Old 09-20-2013, 11:55 AM
Bubba88's Avatar
Henry Co. is down where we were at for the Summit meet to give you an idea on his location.
Where in Henry County are ya? Do you have any type of gauges for the truck?
Nathan --
'04 CCSB FX4 with some go-go parts from the performance section of AutoZone
Bubba88 is offline
post #7 of 18 Old 09-21-2013, 12:14 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That's a drive there for me at least
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 18 Old 09-21-2013, 06:17 PM Thread Starter
sorry that I haven't really been on here to respond and yes I live like 3 miles from summit. no codes that I know of no cel or anything just a skip at idle and really noticeable when not fully up to temp and in the mid rpm range ie 1450 or so only gauges are the stock ones
post #9 of 18 Old 09-21-2013, 07:03 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Have you replaced the crank position sensor?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 18 Old 09-22-2013, 07:12 AM Thread Starter
no I haven't replaced any sensors but I was wondering if the cam position sensor would cause this. I had a good friend of mine that has worked on a lot and I mean a lot of powerstrokes told me to look at the valve cover connections and the injectors. the connectors seem fine and I would rather pin point it the problem then throw money at it by guessing if you know what I mean. thanks for giving me ideas and helping it is very helpful
