WTB: 6.0 EGR valve - Ford Powerstroke Diesel Forum
Georgia Members Georgia Powerstroke.org Members Forum
post #1 of 6 Old 06-24-2013, 03:37 PM Thread Starter
WTB: 6.0 EGR valve
Seeing if someone local has an EGR valve I can pick up for 2003 6.0. I figure most anyone here has EGR deleted.
Truck started doing some funny stuff that makes me suspect the EGR valve does not close fully.
Yes, I know it needs an EGR delete. That's on the list, but time is precious because we have an infant.
Thanks
berusch is offline
post #2 of 6 Old 07-05-2013, 12:38 PM
Bubba88's Avatar
Are you looking for a used one to hold you off? If so, have you tried some junk yards around you? They might have some trucks there and I'm sure the EGR will still be in there (if it wasn't deleted)
Nathan --
'04 CCSB FX4 with some go-go parts from the performance section of AutoZone
Bubba88 is offline
post #3 of 6 Old 07-05-2013, 03:23 PM Thread Starter
Yeah, just looking to get a working valve in there for now so I don't have to look at the codes.
I suspected that my EGR valve was leaking, so I welded it shut. My problem didn't go away (missing when hot).
At some point when I have time, and when the truck is otherwise running well, I'll do a delete. I don't have the 8 hours to spare right now because we have an infant.
berusch is offline
post #4 of 6 Old 07-05-2013, 03:53 PM
asian195's Avatar
Quoted: 2 Post(s)
Just a thought, if you are able to weld, and when you have the time, just weld some plugs in your stock cooler. Almost free that way.
I need to replace my oil cooler and delete egr, right away. But I'm trying to sell some stuff to be able to afford it. As soon as I do, I'll contact you if you still need it, it's almost new. Replaced just over a year ago...
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #5 of 6 Old 07-06-2013, 10:23 PM
Bubba88's Avatar
Are you running a stock tune? IIRC, you'll still need a tune to keep the codes from popping up even when you delete it.
Sent from AutoGuide.com App
Nathan --
Bubba88 is offline
post #6 of 6 Old 07-07-2013, 03:43 AM Thread Starter
Tune is stock as far as I know. I don't mind adding a tune, exhaust, and EGR delete when things are otherwise sorted, but don't want to add any new variables now. Chasing a rough when hot condition. Runs perfect until oil temps get to ~170, starts missing when it warms up.
Replaced a couple of injectors a month ago. It was running great after the injector replacement, and then all of the sudden started running rough. I was halfway through the tank of diesel, driving daily. Starts and runs fine when cold.
berusch is offline
