| Georgia Members Georgia Powerstroke.org Members Forum |
Need help from other Georgians
I installed a coolant filter Saturday morning and it appears to have raised my ECT and EOT by 10* across the board. Before I was running running mid to high 180* on my ECT and mid to high 190* on my EOT during normal around town driving and now my ECT hits mid to high 190* and even low 200* sometimes, with the EOT staying about 8-10* above that. What temps are yall seeing?
Did you do anything else? The install of the filter should not have changed anything. Did you drain and fill or just top off the coolant after install.
I'm seeing about 188-194 on my ECT and +3-+7 EOT in around town driving. That is on a new thermostat and a 25,000 to 30,000 mile old oil cooler. My coolant filter has always been clean when I cut it open. I don't think you can blame the filter install. |
Is the filter clogged? After running the truck for a few minutes (or a short drive, allowing temps to get up to operational temps), touch the filter (but be careful) - if it's hot, then it's cycling correctly. If it's cool, then it's clogged.
Haha, and you definitely don't want to know my delta. My oil cooler is for sure clogged. ![]() It also just may be the weather. It's getting hotter outside. Honestly, your temps seem fine to me. Our trucks like to operate around 205*. That's the ideal spot for our EOT. |
