Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > General High Performance
General High Performance Everything else that involves speed diesel!!!
  #11 (permalink)
Old 06-04-2009, 08:48 PM
Jake Jake is offline
<-----GTP38R
No, you don't need to worry about the wastegate. I'd be willing to bet that the dumbazz that got you worried about it doesn't even know how it works or what it does.
  #12 (permalink)
Old 06-04-2009, 09:01 PM
ruler ruler is offline
I dont know how it works or what it does either so lay some info on me plz
  #13 (permalink)
Old 06-04-2009, 09:08 PM
oh and how do I do the dinger delete that thing is driving me crazy
  #14 (permalink)
Old 06-04-2009, 09:17 PM
<-----GTP38R
What it does - routes exhaust gasses around the turbine wheel of the turbo to prevent over spooling
How it works - there is a red line running to the actuator, that ( i think) pulls a vacuum on the actuator and opens it further as exhaust flow/boost pressures increase.
  #15 (permalink)
Old 06-04-2009, 09:19 PM
<-----GTP38R
The dinger delete i have just makes it not ding when you have the door open with the key in the ignition. Just take a small pointy object, a small phillips head screwdriver works well, put the key in the on position, push the screwdriver into one of the holes on the bottom of the column cover and if you push in the right spot you can pull the entire igniton cylider out. After you do that you will see a little plastic clip with a metal peice sticking up, un hook that clip and put your ignition back in.
  #16 (permalink)
Old 06-04-2009, 10:58 PM
i see in your mods list it says forged. Do certain years come that way?
  #17 (permalink)
Old 06-04-2009, 11:02 PM
ianstew ianstew is offline
wah wah wah
i would assume he means connectiong rods, the later 7.3's came with PMR connectiong rods, which are not as strong. and don't ask what PMR means, because its 2am....lol. i think its powdered metal something, but i could be dead azz wrong
  #18 (permalink)
Old 06-05-2009, 02:01 PM
cliford cliford is offline
yup PMR=JUNK... well actually means powder metal coated rods. there are not as good as the forged rods.
  #19 (permalink)
Old 06-05-2009, 04:23 PM
what years came with the good ones
  #20 (permalink)
Old 06-06-2009, 01:18 AM
<-----GTP38R
PMR means Powdered Metal Rods
Anything before 2000 had forged. 2000 was a the change year, it was a hit or miss, then 2001 on had PMRs. I think some 01s have forged though.
