Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > General High Performance
General High Performance Everything else that involves speed diesel!!!
  #21 (permalink)
Old 03-12-2009, 07:29 PM
AFBLUE AFBLUE is offline
Diesel Fried Chicken!!
Originally Posted by acook024 View Post
yeah i'm pretty sure all SD came with the ZF-6 OBS's had the 5 speed
There were Early 99s that had 5spds. I guess I just asked becuase he didnt post the year.
  #22 (permalink)
Old 03-12-2009, 08:10 PM
acook024 acook024 is offline
Did not know that, Thank you, learn something new everyday.
  #23 (permalink)
Old 03-12-2009, 08:39 PM
strokerman12 strokerman12 is offline
Send a message via MSN to strokerman12
Matt P how much money do you have into doing the intercooler, stage ones and well all the motor parts except the chip and guages and exhaust and how many horses are you getting
  #24 (permalink)
Old 03-12-2009, 08:44 PM
Matt P Matt P is offline
a truck
I have right about at 1 grand with all the parts minus the ones you mentioned, not sure what Im making, last dyno was 300hp and 581 torque but that was with just the injectors and on my street tune, Ill be on the dyno again soon and Id like to make 350 but not sure if that will happen or not, wishful thinking
  #25 (permalink)
Old 03-12-2009, 08:46 PM
well im looking to do the same as you what exactly would i need i have an auto will that hold up to that much power and all i have is the Tw chip and guages and straight pipe stacks in future so what mods do i need??
  #26 (permalink)
Old 03-12-2009, 08:49 PM
a truck
If you want the same as what I have then you just need the mods I have which would be stage 1s, Intercooler, 17* HPOP, and a modded IDM if you want. My stock auto is holding up ok, it is a reman though but if you hammer on it a lot the trans will go, so maybe a valvebody from BTS would be a good idea
  #27 (permalink)
Old 03-12-2009, 08:54 PM
I know this may sound dumb but what is IDM and Stage 1 2 and 3 mean and where did you get your injectors, HPOP, and IDM?? and how much??? and what does the 17* mean and did you put the injectors and HPOP in yourself?? sorry for all the questions but you seem like you have the mods i want and at my price level
  #28 (permalink)
Old 03-12-2009, 08:57 PM
a truck
IDM is the injector drive module which opens up and fires the injectors, you can get it modded to keep the injectors open longer and have them fire faster giving a little more power and faster start ups.
Stages for injectors are the sizes. Stage 1 is 160cc with a stock nozzle, stage 2 is 160cc with upgraded nozzle. Stage 3 can be different size hybrid injectors or not hybrid
HPOP is high pressure oil pump and stock on an OBS and early 99 is 15* 99.5-03 is 17* and can flow more oil pressure to keep up with the bigger injectors
I did all the mods myself
Modded IDM ranges from 100-200 bucks or if your good with soldering and resistors you can do it yourself for basically nothing.
HPOP you can get out of a superduty that has one that is being parted out or whatever
  #29 (permalink)
Old 03-12-2009, 09:02 PM
could i find the HPOP and intercooler on a stock superduty 7.3 at the wrecking yard and where did you get your injectors and how much.. and wats the safest amount of boost with all these mods..or would i be ahead to have jim rosewood to rebuild them bigger for 450 bucks or is that wat you did
  #30 (permalink)
Old 03-12-2009, 09:05 PM
a truck
you could find that stuff off a 7.3 but the IC pipes will have to be modified a little to fit and only a intake spider from an early 99 will work.
I sent my injectors to Jim to have them built, costs 500 bucks.
Your stock turbo is only efficient til like 28 psi or so and you will be safe with these mods. Without an intercooler though I hit 40 which is not good for the stock turbo
