7.3 Bully Dog Problem help!!! - Ford Powerstroke Diesel Forum
General High Performance Everything else that involves speed diesel!!!
post #1 of 5 Old 02-04-2012, 07:46 AM Thread Starter
Last night I installed The Bully Dog GT on my 2000 7.3 all the monitoring is working fine but there are no power settings and no power increase. On the display where the power bars are suppose to be it says "engine warm up mode". It is completely warmed up. Please help if you can.
7.3redneck is offline
post #2 of 5 Old 02-04-2012, 01:58 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Welcom to the ORG. Your problem is its BULLYDOG. They work well for monoriting but power wise the dont work as you found out and will eat your truck. If your gonna get canned tunes go for an edge evolution but your better off getting custom tunes php,TW,TS, etc... Try contacting bullydog to see what they say and good luck
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #3 of 5 Old 04-18-2012, 05:05 PM
I just updated my bullydog tonight and its doing the same thing mines a 99' 7.3 does anyone have a suggestion on what to do?
99Power-Smoke is offline
post #4 of 5 Old 04-18-2012, 05:55 PM
ok I figured it out...go into the defuel defaults and set them to none thats what i did and now its out of "warm up mode" and im able to go through tow,performance,extreme mode using the right hand side buttons
post #5 of 5 Old 04-18-2013, 05:12 PM
bully dog
did you get any power ?
jgo2 is offline
