190cc injectors with stock turbo??? - Ford Powerstroke Diesel Forum
General High Performance Everything else that involves speed diesel!!!
Old 07-22-2011, 01:10 PM
Question 190cc injectors with stock turbo???
I have a 2003 6.0 Powerstroke with almost 150,000 and looks like a few injectors are finally going. Not a bad run with the history of these injectors. I have ARP head studs, FASS 150/180 fuel pump,6.4 banjo bolts, EGR cooler delete, Snow Performance stage 3 Water/Methanol injection, Banks Techni-cooler intercooler, tubes etc...So been looking around and a guy at industrial injection recommended the 175cc injectors but said I would be fine with the 190cc. I have the 03 Turbo everyone seems to like. My truck was built in January 03 so prob one of the first 6.0's to roll out. I was thinking about going with the 190cc's because when this turbo finally goes or I get some extra cash I want to upgrade the turbo for sure and I don't want to look back and wish I had gone with the larger injectors. I pull trailers quiet regularly and is my daily driver. I also plan on doing the Driven Diesel Regulated return kit at the same time. What are your guys opinions??? Anyone out there go with 190cc with stock turbo??? Experiences???
Old 08-25-2011, 04:06 PM
I had 4 injectors go out in my Superduty around two months ago. After calling around to several shops and searching through the forums, I settled on the 155cc injectors mainly because all the people I spoke with said that the stock turbo would not be sufficient for 190cc's. I was told that I also could not pull a heavy trailer with 190's because the EGT's would climb too high. Hope this helps.
Old 09-18-2012, 11:37 PM
BUMP.....
i have the same make and model truck and was also wondering the same question about the 190cc injectors.... my turbo has been doing very well and i want to get some more power out of my truck. so i was wanting airdog 2 fuel system and 190cc injectors..... along with a new headgasket because mine seemed to have failed on me. anyone else have a recommendation on these injectors
