Pulled over by BAR today, more then just visual inspections - Ford Powerstroke Diesel Forum
post #1 of 47 Old 05-26-2009, 03:13 PM Thread Starter
smotrs's Avatar
Tried to do a search for BAR (Bureau Auto Repair) but BAR was too short.
Driving down the road today and came across a check point with a couple officers and some BAR technicians who were spot checking Diesel cars/trucks.
Looked under the hood, looked under the truck (CAT and DPF visual). Connected to the OBDII port. Stuck a probe in the exhaust. Finished with a test on soot levels which involved some sort of white material which was drawn over the exhaust tip. Had me rev it a few times then they removed the piece and measured the amount of discoloration due to soot, I'm guessing.
Guess I was ok, but other then the actual smog checks which they are to begin mailing in January with registration renewals, if this is what we will be facing, were ****ed.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT's
Avic-Z2 Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, Six-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares
Ravelco Anti Theft Device
Originally Posted by Rick Santorum
We went into a recession in 2008 because of gasoline prices.
smotrs is offline
post #2 of 47 Old 05-26-2009, 03:18 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Damn I feel sorry for those of you in cali. Especially those that have Cat and DPF deletes
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 47 Old 05-26-2009, 03:19 PM
7.3toyhauler's Avatar
makes me glad I own a 96
03 f250 fx4 ccsb 4in exh, Egr delete, coolant filter, sct live wire ts with gearhead tunes
7.3toyhauler is offline
post #4 of 47 Old 05-26-2009, 03:39 PM
out trucks dont meet the GVWR to get smogged, but whatever you had sounds crazy im nervous
03 F350 SRW CC LB 4x4
4" Lift, 33 Tires, Pro Comp Trac Bars.
CFM+ Largemouth KIT
MBRP 4" straight pipe
SCT By DJ
ISSpro Gages
Rack it Racks
Debating Fass or RR
dayusex is offline
post #5 of 47 Old 05-26-2009, 04:06 PM
wriott
Guest
Posts: n/a
Quoted: Post(s)
wow im glad i live in michigan
post #6 of 47 Old 05-26-2009, 04:30 PM Thread Starter
smotrs's Avatar
Actually, if you take a look at the BAR website, it's now vehicles that way less then 14,000 GVWR. Here's a link to their website, and here's a quote from the page.
Originally Posted by BAR Diesel FAQ
Will any diesel vehicle be exempt from the program?
Yes, all diesel vehicles over the maximum 14,000 Gross Vehicle Weight Rating (GVWR) limit will be exempt from the Smog Check Program. Some small motor homes will be subject to the program, but most have a GVWR that exceeds 14,000 pounds. The GVWR is indicated on a label located on the chassis or door jam of the vehicle.
Sad thing is, it's not our trucks that our the problem, it's the freaking semi's.
So far, Nevada, New York and Colorado are following suit or already testing.
Shaun
Line-X bedliner
smotrs is offline
post #7 of 47 Old 05-27-2009, 05:03 PM
AvroAero's Avatar
Yea, semis roll coal all day long just driving.
2004 Ford Excursion 6.0
-SCT livewire w/ innovative extreme tunes
-Banks monster exhaust
-Zoodad
-05 conversion w/ harley headlamps & HIDs
-Viper 5900 remotestart/alarm
-ARP studs
-EGR delete
-Defender roof rack with 600W of light
-whelen hideaway strobes
-Sound off Predator dual red-red
-Whelen 500 4 amber 2 blue
AvroAero is offline
post #8 of 47 Old 05-27-2009, 05:45 PM Thread Starter
smotrs's Avatar
I suspect, the only reason it's being done is that it's another source of income due to the fact that diesel is becoming an alternative fuel source for private vehicle use rather then strictly commercial use.
Shaun
Line-X bedliner
smotrs is offline
post #9 of 47 Old 05-27-2009, 05:51 PM
Raging Lunatic
choctaw's Avatar
That's probably closer to truth than one might think.
Halito...Sa hohchifo ut Mike
On EARTH as it is in TEXAS
ΜΟΛΩΝ ΛΑΒΕ
"Fast Service Guaranteed...No Matter How Long It Takes"
choctaw is offline
post #10 of 47 Old 05-27-2009, 05:55 PM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
And the rest of the country ain't far behind.
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
