Rear u-bolts - Ford Powerstroke Diesel Forum
Old 05-13-2009, 05:40 AM
Front u-bolts
Ok I got some 2inch leveling springs for the front and I was wondering if any1 knew what size of u-bolts I should use to replace the old ones? Thanks
Old 05-13-2009, 06:23 AM
aluminum tubing engineer
ill take a stab at it...how about ubolts that are 2 inches longer than your old ones
Old 05-13-2009, 06:45 AM
Well thats a good stab, but not exactly what im looking for thanks.
Old 05-13-2009, 07:21 AM
lol...sorry, its my friday
Its np it was funny
Old 05-13-2009, 07:24 AM
It's the front you need correct? I ask because your subject reads 'Rear u-bolts'
Old 05-13-2009, 07:25 AM
wow yes your right... Thanks
Old 05-13-2009, 07:35 AM
Send a message via MSN to Justinlw
If you just have leveling springs, they should not be much thicker than the stock springs. I temporarily have a 2" add-a-leaf installed in my front springs and the stock bolts still stick out around an 1/2" from the nut.
Measure the thickness of the new spring pack and compare to the stock spring pack. Then measure the amount of bolt sticking out from the nuts on your front axle.
Old 05-13-2009, 08:09 AM
Thanks justin Its just add a leaf to my stock spring pack. Its not good to use the stock u bolts again right? Also off the top of your head do you know if they are square u bolts or round ones. I look at them and I cant really tell a difference.
Old 05-13-2009, 08:14 AM
Actually they are semi-round and should look like these.
Pics inside
You should replace them. Usually a local truck spring shop can make them up for you for about $10 bucks each.
