6in pitman arm on 4in lift? - Ford Powerstroke Diesel Forum
Old 05-09-2009, 08:49 AM
Send a message via AIM to S.S construction
Will a 6 in pitman work on a 4in lift ?
Old 05-09-2009, 09:37 AM
depends. you need to make sure that the drag link angle and the trac bar angle are the same. If they are you are good to go if not you will have bump steer.
Old 05-09-2009, 09:42 AM
ya they are on the same angle
