2002 f250 high pressure problems - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-08-2009, 11:23 AM Thread Starter
Unhappy 2002 f250 high pressure problems
I am working on a 7.3 diesel for a friend of mine.He changed the oil in the truck using 10w30 he drove down the road to go to work and it quit. I checked truck out,it has a code p1212.I checked the high pressure resovior it was empty.I filled this up with oil and still had no icp reading.Any body have any ideas.I have snap-on scanner.The low pressure reading ok.
P.BENESZ is offline
post #2 of 7 Old 05-08-2009, 08:17 PM
Send a message via AIM to kx592
How many Qts did he put in it
1997 7.3 extended cab 8ft.
4" straight piped
DIY intake- 6637 filter
178K on the dash
Boost, PYRO, Trans temp gauges (auto meter)
33" nittos on stock height
kx592 is offline
post #3 of 7 Old 05-09-2009, 05:15 AM Thread Starter
The oil is full 15 quarts rotella t.
P.BENESZ is offline
post #4 of 7 Old 05-09-2009, 06:21 AM
if the HPOP reservoir is empty try putting half a quart or one quart in and try
4" straight piped
178K on the dash
kx592 is offline
post #5 of 7 Old 05-09-2009, 08:32 AM Thread Starter
Tryed that still wont start.High pressure reading only at 8psi.
P.BENESZ is offline
post #6 of 7 Old 05-09-2009, 08:35 AM Thread Starter
I pulled IPR no oil spilled out into valley.
P.BENESZ is offline
post #7 of 7 Old 05-09-2009, 08:37 AM Thread Starter
Im going to look at truck and see if I could see anything.Try other tests.
P.BENESZ is offline
