1995 f350 recent injectors installed hard to start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-06-2009, 08:21 PM Thread Starter
so im new to posting, try to just read other posts to get info. but did a recent injector kit install on two trucks our 1999 f550 and our 95 f350 everything went great on the 550 but the 350 doesn't want to start very easy. while its running it runs great, but if you shut it off and try to restart it just cranks till the battery is almost dead before it fires. the longer you wait to restart the harder it is to start. a tech that used to work for international told me to drive it for 15-20 miles above 2000 rpm to get trapped air out of the oil rails. tried it with no results. if anyone has any info i'd be glad to hear from ya thanks, Garrett wichita ks
lunerman64 is offline
post #2 of 4 Old 05-07-2009, 12:33 AM
Colotow's Avatar
Location: Quit Iraq, got a house in Tooele, Ut, Back in a big wrecker playing in traffic!
might also have air in the fuel rails, and on a 7.3 there's nowhere for it to go except thru the injectors (that's what a regulated return kit fixes!)
on the back of each head, there's a plug (1/4" sq drive) or at the rear, pointed towards the turbo, there's a pipe cap. I did injectors on the girlfriends truck, had to loosen them up and cycle the key a couple times, when I got a steady fuel stream it fired right up and ran great.
did you check the fuel filter for engine oil, make sure you didn't roll or pinch an oring?
99 F350 CC DRW 4x4 PSD 6 spd 4:10 Programmed, 4"exh, 8" lift Kelderman 4 link air ride rear, southbend clutch (and arm!) 295/85R22.5's, AFE stgII gauges, push bar, 07 lights, recon smoked fender and rears, ARE shell, DynaTrak combo front,
, Short throw Shifter, Airdog, Regulated Return fuel, Coolant filter, Bypass Oil Filter. Next:BB Turbo, CAC, Injectors, HPOP, Head studs, and anything else I can afford
Colotow is offline
post #3 of 4 Old 05-07-2009, 07:58 PM Thread Starter
alright so i drained the plugs and let it run with with em open for about thirty seconds. it started right up i let it run for about fifteen twenty min then shut it off and tried to resart it again. and the same conditon as before just cranking and no fire. like it wont start when its warmed up.
post #4 of 4 Old 05-10-2009, 10:36 AM Thread Starter
has to be a starting problem when its at opp. temp. otherwise it starts right up. any ideas?
