AWD Diesel???
Plausible? Possible?
What would be necessary to turn a 7.3 4wd into a 7.3 awd? Discuss... |
why do you want it all wheel drive?
Put it in 4wd and pull the button off the dash...
here is a bump |
I've never seen the topic discussed before.
You need an electronic transfer case, and I think you actually need two transfer cases one for front, and one for back, so you can electronically make it go FWD, RWD, or AWD for terrain applications.
You'd need to find one that is "smart" and detects wheel slip, and then removes power from 1 wheel, and adds more to the other 3 that have grip. |
To make it a good awd would you not have to modify the front axle for better steering?
You'd need a good LS fron't end to unlock one wheel as you turn to keep it from hoping. |
But does it transfer power during wheel spin?
sounds like alot of work
