Bully Dog Triple Dog Power Pup Diesel Downloader Chip - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-22-2009, 05:24 PM Thread Starter
fordpower21's Avatar
for power and fule
good or bad?
fordpower21 is offline
post #2 of 3 Old 04-22-2009, 05:38 PM
GreenF350's Avatar
There is certainly better, if for no other reason then a more custom taylored tune. I don't have a lot of experience with Bully Dog, but if it's been said once, it's been said 100 times. DP Tuner or TW Chips are the way to go. That being said....Seems like they (Bully Dog) chips were hard on transmissions. I might be lying though...Someone else will chime in for sure.
-Aaron
EDIT: This is assuming this is for a 7.3L. Their isn't a lot of info in your post.
2000 Ext. Cab F350 SRW, 6" Skyjacker lift on front/8" BDS Springs on rear w/NO blocks, 37x13.50 Nitto Mud Grappler's, Aftermarket Front Bumper
-Always More Stuff Coming!
GreenF350 is offline
post #3 of 3 Old 04-22-2009, 06:03 PM
Rice Hunter
Diesel Freak's Avatar
I was running a Bully Dog for 2 years. I really liked the outlook options it offered. I did not like missing too many shifts when I mostly depended on it. Shifts were at time erratic
and sometimes failed to even shift. I'm Happy with the SCT with custom tunes presently!!
Hope this helps!
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
