o-rings - Ford Powerstroke Diesel Forum
Old 02-05-2006, 01:58 PM
Question o-rings
i have a 00'superduty 7.3powerstroke and need to know what
type of o-rings go on the fuel lines in and out of the fuel filter
housing
Old 02-05-2006, 02:04 PM
housing
do you have a leak??? there are multiple o rings.....four on the fuel filter housing...two pairs of two different types if i remember right....and then then there is two o rings that are the same on the drain valve that are a common leak point.......what exactly are you looking for???......the type is a true o ring..diameter i dont know......Marc
Old 02-05-2006, 02:15 PM
i'am looking for the size of the 2 larger ones
on the housing.i just clean out the filter housing
and when i start it ,it's like it not firing on all cyl.plus
the one line is real lose and the nut is bottomed out
Old 02-05-2006, 06:38 PM
o-rings
[QUOTE=lance]i'am looking for the size of the 2 larger ones
the one line is real lose and the nut is bottomed out.
plus is there akit for all the o-rings
