rear end question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-17-2009, 03:50 PM Thread Starter
fordpower21's Avatar
Question rear end question
I have a 2001 f250 4 wheel drive, with a 7.3. (not a dually) Iím wondering what are rear-end modifiers? Is a rear-end modifiers something which comes in the oil or do I need to add it to the rear-end oil (70-140). I have no idea.
thanks
fordpower21 is offline
post #2 of 9 Old 04-17-2009, 04:07 PM
Goose350's Avatar
the friction modifiers help with limited slip. Not exactly sure what it does but if you have a limited slip rear end you will need the friction modifier if you change your oil
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #3 of 9 Old 04-17-2009, 04:16 PM Thread Starter
do you add the modifier or does it come in the oil(what kind(70-140), brand)? how can i find out if i have limited slip?
thanks
post #4 of 9 Old 04-17-2009, 04:18 PM
dusted4eva's Avatar
Send a message via MSN to dusted4eva
You need to add it AMSOIL Friction Modifier
2001 7.3 SuperDuty Lariat
AFE Stage II Cold Air Intake
PHP Tunes , Autometer Gauges
Zoodad Mod,
4"SS MBRP Exhaust
ITP Overboost Annihilator
Roada Deco Positive Air Shutoff
NADP Heavy Hauler Transmission
6 liter Trans Cooler
Diesel Site Coolant Filtration System
dusted4eva is offline
post #5 of 9 Old 04-17-2009, 04:23 PM Thread Starter
Would it hurt anything if I add a modifier even if I didn’t need it?
post #6 of 9 Old 04-17-2009, 04:23 PM
dusted4eva's Avatar
NOTE: AMSOIL Synthetic Gear Lubes do not require the use of this additive. However, not all differentials respond the same and if chatter is noticed, the addition of AMSOIL Slip-Lock will eliminate it. For chattering differentials not running AMSOIL Gear Lube, this product is an excellent solution to the problem.
Zoodad Mod,
4"SS MBRP Exhaust
post #7 of 9 Old 04-17-2009, 04:26 PM
dusted4eva's Avatar
If you don't need it don't put it in or just use Amsoil Synthetic Gear Lube and voila.
Zoodad Mod,
4"SS MBRP Exhaust
post #8 of 9 Old 04-17-2009, 04:31 PM
Goose350's Avatar
Im about to do mine and Im putting Royal Purple in and it has the modifier already
The Mullet Mod
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #9 of 9 Old 04-17-2009, 04:35 PM
dusted4eva's Avatar
Woo hoo. Royal Purple is good stuff too.
Zoodad Mod,
4"SS MBRP Exhaust
