Need Advice - Ford Powerstroke Diesel Forum
Old 02-04-2006, 08:33 AM
Need Advice
Im New To Diesel Trucks And Am Looking To Buy. I Have Been
Looking At A Few Powerstrokes And Dont Know What Years
Are Better The The Next. What Would Be Better A 97 Or 2000?
Also What Are Some Of The Inherent Ploblems You Have With
Them, Turbos, Injectors, Pumps, Ex. ?
Old 02-04-2006, 10:16 AM
if i was buying one myself, i would get a 99.5-2003 7.3. they are very reliable and have plenty of power, and handle modifications very well. the most common problems with them are cam sensors failing, injectors failing, water pumps seem to last about 100-150,000 miles, and the harnesses for the injectors under the valve covers sometimes have the clip weaken and they will come partially disconnected causing a rough running condition. none of these problems are an epidemic or anything, although the cam sensor is a very common problem. i reccomend keeping one in the glove box so you dont end up stranded, and its very easy to replace. Dont take this as it is a motor with a lot of problems, cause its not, these are just the most common things i see working on them..........Marc
Old 02-04-2006, 01:27 PM
99 or 99.5 ?
How Do You Tell Between A 99 Or 99.5?
Old 02-04-2006, 02:09 PM
look at the build date on the drivers door tag....you want one built after 12/07/1998....that is a 99.5 motor.....
Old 02-04-2006, 06:27 PM
97 powerstroke
You recommend 99.5-03. I have been looking at this very nice
97 f-250, how do they compair.
