Open diff options.... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-11-2009, 06:16 PM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Hey, I just found out my dually has an open diff when I asked Scott to rebuild the LSD. Well, I had heard of something that you can put in in your driveway, not really a locker, but something to make it a LSD? is this true?
Is a locker in it my only option to get both sides to pull in the snow/mud?
Also, I am assuming the front is an open diff too. How can I tell? is there anything on the tag on the cover that tells it?
Mines a 10.25 dana 80. 3:73 gear.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 5 Old 04-11-2009, 06:20 PM
dzchey21's Avatar
If you give your tag numbers to a place like drivetrain or somone who builds axles they can tell you. As far as a "powertrax" type locker in a dana 80 i dont think its possible. I do a little looking but for the most part that is for like 10 bolt chevy axles ect. ill do some looking at get back to you.
single turbo'd 6.4
dzchey21 is offline
post #3 of 5 Old 04-11-2009, 06:24 PM
back in the saddle
shu873's Avatar
My advise would be to install a tru trac in it and be done Nick. I don't like full lockers for a street truck.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #4 of 5 Old 04-11-2009, 06:28 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Thats what I was thinking Kurt, not a full locker.
Nick
"The Mistress"
post #5 of 5 Old 04-11-2009, 06:33 PM
dzchey21's Avatar
They do make a loc rite for the dana 80 but it says not for high horsepower or big tires... its cheaper though and easier to install.... but diffs arent that hard to set up really just time consuming. As far as the front a selectible locker or a open diff are about the only way to go. Full lockers or even limited slips make it tricky to drive on slick streets because it wants to make the truck push really bad.
single turbo'd 6.4
dzchey21 is offline
