Supporting Mods with Programmer
Is it neccessarry to upgrade to a fuel pump and bigger oil ect when adding just a chip to your truck? I've seen some people (mainly cummins) usually have the Fass system when they add a chip. Any Input?
The only thing you really need when you add a chip to your truck is gauges. Your engine tuner will work with you and tune your truck according to what you have done to it. If you have added a fuel system or a HPOS and bigger injectors, then they will tune your truck accordingly. If your truck is stock, they will tune it accordingly for that also.
If you are buying canned tunes, then you will be fine with stock fuel and oil. That is what they all take into acct. But don't forget the gauges!
But who knows it may have not been inflicted by the tuner itself, just seems like a lot of problems arise when people tune their trucks |
you got all the supporting mods you need for a chip, a fuel system is a necessary supporting mod for a cummins right off the bat cuase that is their weak point for the 24valve and common rail
ohh. gotcha
Yup the lift pump goes out on the dodges which kills the VP44 on the 24 valves or the CP3 on the common rails
