2wd to 4wd conversion
So i heard that you can do a 4wd conversion on a 2001 2wd with 2005 parts. Everything pretty much matches up from what i hear just a couple little things are different. Has anyone done this or know of anyone that has done this??
with all the parts it can be done but its gonna be a lot of work and time i hope you have some good friends that will help you and another vehicle to drive while you are doing the work.. good luck
Thats the thing i gotta find the parts cheep, maybe find crashed up 05 gasser? I heard it would be cheeper then if i did the same year because of the coil spring setup. If i had to by the idividual parts what do you think i would need to buy?
When it comes down to it its just welding, cutting, and bending metal to make it work. If you use a manual transfer case it's not hard at all. Another member here (Dlonno) put a straight axle on his 05 2wd. You gotta look at the situation and the vehicle. 4wd conversion on a Ford not hard at all. 4wd conversion on a Dodge looks way hard.
You'll also need a 4wd tranny though.
Wait what do you mean i 4wd tranny??
2wd tranny's have minor different internals. I think the output shafts are different in the 4wd trannys vs. the 2wd tranny's.
Oh alright that would make sense.
Does anyone else have information on this??
why put a 05 why not a 99-2004 i have the whole set up on a parts truck
call me if tomorow interested 618-638-3174 |
