AA with AOs? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-09-2014, 08:04 PM Thread Starter
AA with AOs?
So I have a 95 7.3, and after diagnosing the grey smoke and lack of power, inside a contribution test and 3 injectors failed. I had a set of AAs out of 96 junk yard truck and 2 AOs out of a 94. I took them all to get tested, and I was
Wondering if I could run the AAs and the AOs together if that is my option without having the AAs rebuilt if need be. Thank you!
4x4stroker95 is offline
post #2 of 2 Old 07-20-2014, 01:31 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The aa and ao are both about 90cc single shot injectors, for all intent and purposes they are identical as far as anything goes for running them
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
