My truck is shaking at idle - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-08-2014, 09:49 PM Thread Starter
I own a 05 powerstroke with 198k miles on it! Today I started up my truck and it began to shake(not violently)but shoke the whole truck a good amount, the engine was already at operating temp so I reved it up, (thought it was just a fuel thing). I have no idea wat could cause this! Once I begin to drive it will smooth out and go away! If I'm at red light for more than 15-20 seconds it will start to shake again! I would really appreciate someone's knowledge in this!
Arp head studs
Powermaxx turbo
Egr delete and upgraded oil cooler
Upgraded fuel regulator
AirRaid direct cold air intake
All brand new gaskets all the way around!
4" magnaflow turbo back straight pipe
Dark1244 is offline
post #2 of 4 Old 07-09-2014, 12:49 AM
brscott38's Avatar
Sounds like an injector starting to go. Did you check for any codes?
brscott38 is offline
post #3 of 4 Old 07-09-2014, 06:31 AM Thread Starter
Do you mean like a engine light that came on?
Arp head studs
Powermaxx turbo
Dark1244 is offline
post #4 of 4 Old 07-09-2014, 09:54 AM
brscott38's Avatar
You need a scanner to do code scan
