Serious/Annoying Vibration - Ford Powerstroke Diesel Forum
post #1 of 22 Old 07-01-2014, 04:42 PM Thread Starter
mcdizzle's Avatar
Hey guys here's the scoop, I have a 2000 f350 with 199,500 miles on her. She has a 4.5" Icon hanger kit lift(approx. 3 years old) and new 285/75/16 Toyo Open Country AT tires as of yesterday and while having the tires put on I had them check alignment also. I replaced all three u joints and carrier bearing approx. one month ago. While driving I am getting a pretty good vibration and i'm not sure where it is coming from, once I hit about 45 mph it starts and around 65-75 it is almost unbearable. It seem while i'm at highway speeds it seems to kinda go away when I let completely off the pedal. What is your guys take?
2000 F-350 XLT 7.3L
200K miles
4" MBRP Turboback Exhaust
MBRP Muffler Delete Pipe
Airaid CAD intake
Edge Evolution Programmer
4.5" Icon Lift
mcdizzle is offline
post #2 of 22 Old 07-01-2014, 05:49 PM
sbluke55's Avatar
Quoted: 624 Post(s)
Garage
When did it start? Do you feel it more in your seat or your steering wheel?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #3 of 22 Old 07-01-2014, 05:56 PM Thread Starter
mcdizzle's Avatar
It has been this way for a little while now not really sure when it started. I feel it more in the seat, I noticed the steering wheel feels pretty smooth.
2000 F-350 XLT 7.3L
200K miles
Airaid CAD intake
4.5" Icon Lift
mcdizzle is offline
post #4 of 22 Old 07-01-2014, 07:28 PM
sbluke55's Avatar
Quoted: 624 Post(s)
Garage
How high did you lift the rear? Did you shim the carrier bearing? Have you ever pulled the slip yoke apart?
01 f-250, Standard
post #5 of 22 Old 07-02-2014, 02:50 AM
Seydler3's Avatar
Is the drive shaft in phase?
2004 6.0 ECLB
SCT X4
4" turbo back straight pipe
Seydler3 is offline
post #6 of 22 Old 07-03-2014, 06:59 PM Thread Starter
mcdizzle's Avatar
The drive shaft has never been taken apart so it should still be phased correctly. Today I decided to pull the rear driveshaft and throw it in 4x4 and take her for a drive and see what would happen, I found that there was no vibration at all now from 0-90mph. What are the best u joints for super dutys and how much should the carrier bearing be shimmed with this setup. I never did shim the carrier bearing.
2000 F-350 XLT 7.3L
200K miles
Airaid CAD intake
4.5" Icon Lift
mcdizzle is offline
post #7 of 22 Old 07-03-2014, 07:31 PM
sbluke55's Avatar
Quoted: 624 Post(s)
Garage
What's your arrangement? Sclb or scsb. I'd use spicer, Moog or oem for U-joints. My guess is 1"-1.5" of spacer but it all depends on your arrangement.
01 f-250, Standard
post #8 of 22 Old 07-03-2014, 07:35 PM Thread Starter
mcdizzle's Avatar
Extended cab long bed
mcdizzle is offline
post #9 of 22 Old 07-03-2014, 07:45 PM
sbluke55's Avatar
Quoted: 624 Post(s)
Garage
1.25". If you get a small vibration on take off add an 1/4". Also replace your carrier bearing. If you don't feel like messing with the u joints and carrier bearing take if to a drive line shop and have them replace everything and do a balance.
01 f-250, Standard
post #10 of 22 Old 07-03-2014, 07:51 PM Thread Starter
mcdizzle's Avatar
How often does a driveline need to be balanced or only when you're having issues? Where did you come up with a 1.25", just wondering for future reference.
2000 F-350 XLT 7.3L
200K miles
Airaid CAD intake
4.5" Icon Lift
mcdizzle is offline
