help. unleaded gasoline in my tank - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-25-2014, 08:49 AM Thread Starter
Unhappy help. unleaded gasoline in my tank
I have been under a lot of stress lately, so like a walking zombie I filled up half of the tank of my 99 f350 (7.1) with regular gasoline. The truck rides fine and I have not had any trouble so far ( I drove to work for about 25 miles). Any feedback and suggestion is greatly appreciated.
joe.411 is offline
post #2 of 5 Old 06-25-2014, 08:53 AM
ZMANN's Avatar
Quoted: 1891 Post(s)
u must be a zombie to call your 7.3 a 7.1
if it were mine i would be draining everything and doing filters
some say u might be ok on the 7.3 if u drop some oil in the fuel
lets see what others suggest
if it were a newer truck you wouldn't be so lucky
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
post #3 of 5 Old 06-25-2014, 08:53 AM
SuperCrutyPS's Avatar
Quoted: 343 Post(s)
Garage
I think the general consensus is that you should drain your tank, fuel lines and change your fuel filter before driving it anymore.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #4 of 5 Old 06-25-2014, 01:31 PM
Vannnce's Avatar
Quoted: 13 Post(s)
my neighbor completely filled his 09 cummins with unleaded while pulling his fifth wheel across a couple states. He siphoned about half a tank in to two big coolers he had, and filled the rest with diesel. Ran it like that hauling his fifth wheel with no problems. Said it "ran hot and lacked power" but no adverse affects.
Personally id be draining as much of that as i could, like all of it, and changing filters
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #5 of 5 Old 06-28-2014, 07:08 PM
Quoted: 2 Post(s)
Drain as much as you can & refill it with diesel, and you should be fine.
I wouldn't run a 50/50 blend... get it down sub-5% and it's probably OK (not great, but at least reasonable).
Syonyk is offline
