new to this site.
hi i am new to this site and could appriciate some help on some questions i have. I have a 2004 crewcab 6.0 and have owned it since new, with knock on wood with very few problems! but i just went out of my 100k warranty! and now i am wooried about all the problems i hear about with this engine. i was curios about the injectors, is there any previntiive maint. that one can do to keep them running.
![]() ![]() ![]() ![]() ![]() I don't know the 6.0 but someone should be along shortly that can give some advice! ![]() |
welcome to the Org...
i really dont hear that much about injector problems on the 6.0L... the main stuff that can go wrong is EGR and headstuds.... if you want to do some preventative mods then do a EGR delete and ARP headstuds... but its not cheap.. labor on headstud work is in the 1k+ range... hope this helps... let us know i you have any other questions -Raul |
welcome to the ORG
RUN SOME DIESEL KLEEN OR STANADYNE TO CLEAN AND LUBE THE INJECTORS, SINCE THE NEW ULTRA LOW SULFUR FUEL HAS NO LUBRICITY. |
WELCOME TO ORG ! !
Drain the HPOP!!!
![]() ![]() ![]() J/J...I don't know if you know about powerstroke help.com but the threads having been going around for a while... welcome to the org! ![]()
thanks you guys, i have a completely stock set up are the head studs still an issue? i am planning on changing the exhuast turbo back 5", will i need to worry about changing any thing else? could some one explain more about the egr? is that the valve that there is a maint. post on how to clean? my business has 1 other 04 6.0, and an 04 excursion w/ 6.0 they both had to have the injectors replased, so that is why i am concerned my truck is also an o4,6.0! thanks for the help so far guys, been great.
The best thing you can do for your injectors is to keep your fuel and oil filters changed and keep up to date on regular maintenance. A bypass oil filtration system such as the FS-2500 is also a good idea. The '03 C94 injectors were a little more quirky than the later models. IIRC Ford went to C95s after May '03 builds.
Head studs are a good idea on even stock applications, but I wouldn't worry about it too much unless you are experiencing problems. And yes the EGR is the valve that you have read about cleaning. Read this article for more info on the system, I'm too lazy to type it all out,, http://www.forddoctorsdts.com/articl...icle-05-01.php And welcome to the ORG. |
