FPR Shim Question - Ford Powerstroke Diesel Forum
Old 01-14-2009, 04:29 PM
FPR Shim Question
Hi I have a 96 psd and I recently did the FPR shim I used a 3/16" BB. When I checked the fuel Pressure it raised it to 90 psi. A lot of guys say not to go over 70 psi Should I use a smaller shim?
Old 01-14-2009, 05:01 PM
PMR = JUNK
YES! You're gonna blow fuel lines if you don't.
Old 01-14-2009, 06:07 PM
LoL wow yea i'd reduce that bad boy! Also on ebay not sure if good or not there is a fuel spring that does the same thing!
