Good Deal or Hidden Issue? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-21-2014, 07:39 PM Thread Starter
A local non-Ford dealer a 2001 F350 7.3L ,83K miles, ext cab, long bed, 4x4 asking $12k. Claims the truck was a single owner and only mechanical "issues" are, "A valve cover leak and oil pan leak that are not bad leaks."
I may go take a look at it but before I do, does this deal sound too good to be true??
I'm not familiar with these trucks nor the cost to repair these items.
You advice is appreciated.
Sasmaster6000 is offline
post #2 of 5 Old 06-21-2014, 07:59 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
Valve cover is easy. Oil pan not so much. You have to pull the whole motor to fix it. I bet that's why it's going so low. Around here that truck would be on the market for at least 20k. I would buy it. It would save some coin if you could do it your self. Also make sure it's cold when you start it and check for blow by. To do it start it then flip the oil cap over and set it back on the fill tube. If it blows off it needs rebuilt. If it rattles off it's all good.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 5 Old 06-23-2014, 03:01 PM Thread Starter
Thanks for the info. Anyone know roughly how much a shop would charge for this fix?
post #4 of 5 Old 06-26-2014, 02:39 PM Thread Starter
OK, If I (or a shop) were to pull the engine out, what other components should I consider replacing / upgrading at that time? Water pump?
post #5 of 5 Old 06-26-2014, 06:10 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
I'd do up pipes. And check for leaks on your rear main. The rest is really easy to get to. Check your front cover also. If you need to pull it the pan needs to come off. I have no clue on price to pull it
01 f-250, Standard
sbluke55 is offline
