How To Get A Oasis Report? - Ford Powerstroke Diesel Forum
Old 01-10-2009, 06:31 PM
Oasis, how to get it.
Old 01-10-2009, 06:33 PM
Rice Hunter
You should get it free for the asking since yer a paid up member
Old 01-10-2009, 06:34 PM
Dont understand what that means.
Old 01-10-2009, 06:36 PM
Location: Little Rock Air Force Base,Arkansas and North Augusta,South Carolina
if your a premium member then you get an oasis free, one of the mods should be able to help you out.
Old 01-10-2009, 06:40 PM
So if I just sign up I just need to ask the mods. Whats the usual eta on them.
Old 01-10-2009, 06:42 PM
your guess is as good as mine.
Old 01-11-2009, 05:47 AM
Slacker
Feedback Score: 4 reviews
We run them free for premium members and it usually only takes a day or two to get them, if we aren't busy. You can also get them from any Ford dealership for free.
Old 01-11-2009, 01:43 PM
Old 01-11-2009, 02:07 PM
PM me your VIN and I have access to the Canadian oasis and it should have your info also
Old 01-12-2009, 05:00 AM
Here is what I have so far. I have figured out most of it and want to know what you think.
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 0 1A03 030100 * 6006 * L65 D1 330
AWS Claim Key: 1212259 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01237 - * Name: KINDLE FORD MERCURY-LINCOLN, INC. Ph: 609-4655000 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2003 Doc #:23187901
Cust Comments: CHK FOR OIL LEAK
Tech Comments: FOUND SLIGHT FILM AREA OF BELL HOUSING ADD DYE AND LEAK CHECK NO OIL LEAK FOUND
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 3 2G04 031401 * 12A650 * D41 42 4305
AWS Claim Key: 1998663 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01237 - * Name: KINDLE FORD MERCURY-LINCOLN, INC. Ph: 609-4655000 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2003 Doc #:23691901
Cust Comments: IDLE RACES SOMETIMES AND SOMETIMES FEELS LIKE IT GETS NO FUEL
Tech Comments: INSTALL WDS AND REFLASH WITH LATEST UPDATE
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 6 2G04 031401 * 12A650 * D13 42 9187
AWS Claim Key: 3096488 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01237 - * Name: KINDLE FORD MERCURY-LINCOLN, INC. Ph: 609-4655000 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2003 Doc #:24242901
Cust Comments: CHK FOR ROUGH IDLE
Tech Comments: INSTALL LATEST CALIBRATION UPDATE FOR 6.0L DIESEL
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 8 1A02 030102 * 6051 * E68 D1 14043
AWS Claim Key: 4111213 Trx Code: E84 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 01237 - * Name: KINDLE FORD MERCURY-LINCOLN, INC. Ph: 609-4655000 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:07-JAN-2004 Doc #:24657102
Cust Comments: FUMES FILLING TRUCK WHEN WARMING UP
Tech Comments: FUEL RAIL DRAIN PLUGS IN LEFT CYLINDER HEAD LEAKING ACCESS AND REPLACEPLUGS
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 8 1D01 030008 3C3Z 6701 AA L65 D8 14043
AWS Claim Key: 4111212 Trx Code: E84 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 01237 - * Name: KINDLE FORD MERCURY-LINCOLN, INC. Ph: 609-4655000 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:07-JAN-2004 Doc #:24657101
Tech Comments: REAR MAIN OIL SEAL LEAKING R AND R TRANS AND TRANSFER CASE REPLACE REAR MAIN SEAL
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 8 2H01 030008 3C3Z 6K854 DA E68 01 14470
AWS Claim Key: 4332949 Trx Code: E84 Labor Hrs: 12.6
Dlr Cd-Sub Cd: 01237 - * Name: KINDLE FORD MERCURY-LINCOLN, INC. Ph: 609-4655000 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2004 Doc #:24741301
Cust Comments: FUEL FUMES INSIDE WHEN ENGINE WARMS UP
Tech Comments: PERFORM VISUAL INSPECTION HOOK UP SMOKE MACHINE AND SMOKE TEST TRACES COMING FROM MANIFOLD Y PIPE INSPECT PIPE FOUND TO BE CRACKING R AND R TRANS HAUST MANIFOLDS AND TURBO AND REPLACE MANIFOLD Y PIPE
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 8 2H02 030008 * 6F089 * D36 X2 14470
AWS Claim Key: 4406006 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 01237 - * Name: KINDLE FORD MERCURY-LINCOLN, INC. Ph: 609-4655000 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2004 Doc #:24741302
Cust Comments: POOR ACCELERATION CHK ENG LIGHT WAS ON
Tech Comments: PERFORM WDS DIAG REPAIR PIN IN CONNECTOR FOR VGT SOLENOID
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 10 2E03 030402 * 9F593 * D50 42 17674
AWS Claim Key: 5122719 Trx Code: S07 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 01237 - * Name: KINDLE FORD MERCURY-LINCOLN, INC. Ph: 609-4655000 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2004 Doc #:25046702
Cust Comments: CHK ENGINE LIGHT ON LACKS POWER
Tech Comments: R AND R VALVE COVERS INSPECT FUEL INJECTOR WIRING HARNESS FOR CHAFFING
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 10 2H02 030008 3C3Z 6F089 AA D50 42 17674
AWS Claim Key: 5122718 Trx Code: S07 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 01237 - * Name: KINDLE FORD MERCURY-LINCOLN, INC. Ph: 609-4655000 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2004 Doc #:25046701
Cust Comments: CHK ENGINE LIGHT ON AND LACKS POWER
Tech Comments: INSTALL WDS AND ROAD TEST CODE FOR TURBO PERFORMANCE CHK VGT ON TURBO WHILE WATCHING EBP NO CHANGE IN EBP OHM TEST WIRING FROM VCT TO PCM REPLACE NSOR AND PFE SENSOR AND ROAD TEST
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 10 2H01 030008 3C3Z 6K682 AARM D50 42 17674
AWS Claim Key: 5151824 Trx Code: S07 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 01237 - * Name: KINDLE FORD MERCURY-LINCOLN, INC. Ph: 609-4655000 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2004 Doc #:25046703
Cust Comments: CHK ENG LIGHT COMES ON AND NO POWER AND SMOKE FORM EXH
Tech Comments: PERFORM DIESEL DIAG CODE P2263 LOW IDLE 614 PSI FUEL PUMP PRESSURE 50 PSI REPAIR #1 FOLLOWING SSM 17472 REPLACE VGT SENSOR TURBO STILL LAGS FROM IDLE TO 2200 RPM THEN WILL KICK IN TURBO BOOST REPLACE TURBOCHARGER
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 17 6Y20 000079 * RAV * A98 42 21512
AWS Claim Key: 8394171 Trx Code: RAV Labor Hrs: 1
Dlr Cd-Sub Cd: 04015 - * Name: AUTOLAND OF NEW JERSEY, INC. Ph: *-* St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:18-OCT-2004 Doc #:07394651
Cust Comments: SAFETY INSPECTION
Tech Comments: SAFETY INSPECTION
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 17 2G01 * * * * * * 21512
AWS Claim Key: 8394174 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04015 - * Name: AUTOLAND OF NEW JERSEY, INC. Ph: *-* St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:18-OCT-2004 Doc #:07394656
Cust Comments: CUST STS RECALL 03L12
Tech Comments: PERFORM RECALL 03L12
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 17 2G04 031401 * 12A650 * G29 42 21512
AWS Claim Key: 8394172 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04015 - * Name: AUTOLAND OF NEW JERSEY, INC. Ph: *-* St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:18-OCT-2004 Doc #:07394652
Cust Comments: EXHAUST SYSTEM VISUAL SMOKE
Tech Comments: EEC TEST DIAGNOSIS
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 17 2A01 031201 4C3Z 9N622 AA P59 42 21512
AWS Claim Key: 8394173 Trx Code: E84 Labor Hrs: 8.2
Dlr Cd-Sub Cd: 04015 - * Name: AUTOLAND OF NEW JERSEY, INC. Ph: *-* St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:18-OCT-2004 Doc #:07394654
Cust Comments: ODOR PASS COMPARTMENT
Tech Comments: AUTOMATIC TRANS ASSY
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 17 6Y05 000001 * TDRIVE * A96 42 21512
AWS Claim Key: 8394175 Trx Code: R7U Labor Hrs: 1
Dlr Cd-Sub Cd: 04015 - * Name: AUTOLAND OF NEW JERSEY, INC. Ph: *-* St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:18-OCT-2004 Doc #:07394657
Cust Comments: 1 HOUR ROAD TEST
Tech Comments: 1 HOUR ROAD TEST
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 20 6F49 010103 * 2850202 * R10 68 22418
AWS Claim Key: 9176394 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 00017 - * Name: PLAZA FORD, INC. Ph: 410-8772800 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2005 Doc #:152046A
Cust Comments: CST WATER LEAK PASS FT A PILLAR
Tech Comments: RESEALED LEFT SIDE ROOF SEAMS, LEFT SIDE WINDSHIELD AND PILLAR SEAM, POOR SEALER.
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 38 * * * * * * * 68992
AWS Claim Key: 14059697 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00017 - * Name: PLAZA FORD, INC. Ph: 410-8772800 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:29-JUN-2006 Doc #:180179C
Cust Comments: PERFORM RECALL 06E17
Tech Comments: RECALL 06E17
AWS Claim Key: 14059696 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00017 - * Name: PLAZA FORD, INC. Ph: 410-8772800 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:29-JUN-2006 Doc #:180179B
Cust Comments: CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: RECALL 59B01
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 38 2E05 100106 6C3Z 9B249 A G29 42 68992
AWS Claim Key: 14059698 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00017 - * Name: PLAZA FORD, INC. Ph: 410-8772800 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:29-JUN-2006 Doc #:180179F
Cust Comments: DRAIN WATER SEP
Tech Comments: REPLACED WATER IN FUEL SEPERATOR, TSB 06 06 05.
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 43 1G01 03XXXX 4C4Z 8592 AA L87 D1 80452
AWS Claim Key: 14660584 Trx Code: E72 Labor Hrs: 5
Dlr Cd-Sub Cd: 00017 - * Name: PLAZA FORD, INC. Ph: 410-8772800 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:27-NOV-2006 Doc #:187315E
Cust Comments: CUST STATES THAT HE HAS BEEN HAVING TO ADD COOLANT
Tech Comments: PRESSURE TESTED COOLING SYSTEM. R&R EGR COOLER, REPLACED WATER CONNECTOR HOSE, LEAKING. REPLACED OILCOOLER CAP, LEAKING.
1FTNW21P43EC99723 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2003 31-MAY-2003 116443 USA 43 2E06 030008 3C3Z 9F838 EA L65 D1 80452
AWS Claim Key: 14660583 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 00017 - * Name: PLAZA FORD, INC. Ph: 410-8772800 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:27-NOV-2006 Doc #:187315C
Cust Comments: CUST STATES NOTICED LARGE PUDDLE ON DRIVEWAY.APPEARED TO BE FROM TRANS. HOUSING. CK AND ADVISE
Tech Comments: LEAK TESTED ENGINE. REPLACED ICP SENSOR, LEAKING.
