scange with xgauge - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-14-2014, 06:44 AM Thread Starter
scange with xgauge
What are the best readings to watch for my 6.0 2007? With the scangauge with xgauge.
exclhn is offline
post #2 of 2 Old 06-14-2014, 06:53 AM
I have the same truck you have with a scangauge also.
Seeing as how we can only display four values at a time, I always have Engine Oil Temp and Engine Coolant Temp displayed, for the remaining two, I have "instantanious MPG" (it has improved my driving habits) and the last one is a wild card which I switch out regularly so I grow accustom to typical values of other parameters. When towing, this one is on "load"
2007 F-350 W/Lariat package
4x4 6.0l diesel engine
Leveling kit and 35 inch tires
Coolant Filter kit
EGR Delete Kit
Glowshift Gauge Pillar Pod (EGT, Trans Temp, Fuel Pressure and Coolant Pressure)
Fuel System Blue Spring Upgrade
SCT Tuner
Diamond Eye 4" stainless steel turbo back exhaust kit
ScanGuage II
Zoodad Mod
Backup Cameras from Tadibrothers.com for both truck and 25' Travel Trailer
DJGut is offline
